2000 Blazer Head Light Problem
Old Feb 11, 2010 | 03:24 PM
mrammo's Avatar
mrammo is on a distinguished road
Default 2000 Blazer Head Light Problem
I have a 2000 Blazer.I'm having a problem with the right side headlight and highbeam.The lights stay very dim,but the left side lights work fine.Any help would be appreciated.Thanks,Mike
Old Feb 11, 2010 | 06:02 PM
Are both low beam and high beam affected?
It is possible that the daytime running lights relay has failed in the open position which ties the driver side low beam and high beam into parallel operation. It could also be the headlamp grounding relay stuck in the closed position.
Here is a conglomeration of schematics that I just put together and marked up:
It is quite a confusing setup, but check out the daytime running lights relay. Swap it with another 5 pin relay of the same size in the underhood fuse block and see if the problem goes away.
Old Feb 12, 2010 | 07:49 AM
mrammo's Avatar
I replaced the day time running lights relay.Having the same problem.Do you know where the headlamp grounding relay is located.Thanks
86bigred
Mar 21, 2015 08:38 PM
Rumblur
May 22, 2013 03:23 PM
echo1
15
Aug 28, 2012 07:56 PM
J.R. Clay
Mar 17, 2011 08:22 PM
ludvigsen08
Aug 14, 2010 04:20 PM
