2000 blazer help and info....
so im new to the chevy world,i bought a 2000 blazer 4.3liter 4x4 with a 2001 extreme engine in it, now the problem im havin is the check engine lite is on because of the knock sensor, now i really dont want to have to pull the motor to tap the block to get the knock sensor to fit and clear the code what is a alternative? can i use the old 2 wire knock sensor from the 2001 motor and some how trick the computer to think its a 1 wire? or does anyone hardware store sell some kind of reducer that i can use the new knock sensor and a reducer to get it to work.....HELP PLEASE
Are you sure your block is not machined correctly already? There are two knock sensors shown for the '01 so you could have either the bolt on or the thread in.
As far as the sensor goes, I would have to look at a wiring diagram to be sure, but I would bet that the two wire sensor is just a ground and sensor output. I do not believe it really matters which is which due to the way a knock sensor works, but again, I would have to verify that by looking at the wiring diagram. |
thanks and please let me know....
The wiring diagram for the two wire sensor shows both wires going back to the PCM. After reading up on them, it would not appear that they are compatible.
Here is a little run down on the two different knock sensors: Purpose: The knock sensor (KS) system enables the Powertrain Control Module (PCM) to control the ignition timing advance for the pest possible performance while protecting the engine from potentially damaging levels of detonation. the sensors in the KS system are used by the PCM as microphones to listen for abnormal engine noise that may indicate pre-ignition/detonation. Sensor Description: There are 2 types of KS currently being used:
Both sensors use piezoelectric crystal technology to produce and send signals to the PCM. The amplitude and frequency of this signal will vary constantly depending on the vibration level within the engine. Flat response and broadband KS signals are processed differently by the PCM. The major differences are outlined below:
KS diagnostics can be calibrated to detect faults with the KS diagnostic inside the PCM, the KS wiring, the sensor output, or constant knocking from an outside influence such as a loose or damaged component. In order to determine which cylinders are knocking, the PCM uses KS signal information when the cylinders are near Top Dead Center (TDC) of the firing stroke |
thanks for the info
