2000 Blazer LS sunroof wont close
Old Aug 12, 2016 | 09:42 AM
Philip Mildren's Avatar
Philip Mildren is on a distinguished road
Default 2000 Blazer LS sunroof wont close
Started this thread because the older threads have dead links.
The sunroof opened partially, closed it partially, and then opened it fully. The shade and glass are both recessed into the roof with the shade being further in than the glass. When I hit to open button, there is a sound from under/above the driver side visor, as if a relay is tripping. When I hit the close button, no sound. Either way, there is no movement from the sunroof.
From this, I am making a few assumptions. The fuse is good, but there maybe an issue with the relay? That or the glass has come off track or something else that Im not really sure of.
Came here looking for guidance, links on how to remove the roof liner to gain access to the sunroof motor, or maybe a trick/tip to keep from having to remove the roof liner.
Thanks in advance.
Old Aug 12, 2016 | 12:49 PM
LesMyer's Avatar
Attached Thumbnails 2000 Blazer LS sunroof wont close-89347044_zpskpiv1e5j.gif
Old Aug 12, 2016 | 12:50 PM
LesMyer's Avatar
Attached Thumbnails 2000 Blazer LS sunroof wont close-89346726_zpslm8vcs9q.gif
Old Aug 12, 2016 | 12:57 PM
LesMyer's Avatar
Attached Thumbnails 2000 Blazer LS sunroof wont close-156276192_zpsdi3b8oxr.gif
Old Aug 12, 2016 | 12:59 PM
LesMyer's Avatar
Attached Thumbnails 2000 Blazer LS sunroof wont close-156088719_zpsgsb9kzdl.gif
Old Aug 12, 2016 | 01:00 PM
LesMyer's Avatar
Attached Thumbnails 2000 Blazer LS sunroof wont close-89346921_zpsqtpqpylz.gif
Old Aug 12, 2016 | 01:01 PM
LesMyer's Avatar
Attached Thumbnails 2000 Blazer LS sunroof wont close-89346922_zpszsxgszdh.gif
Old Aug 12, 2016 | 01:02 PM
LesMyer's Avatar
Attached Thumbnails 2000 Blazer LS sunroof wont close-89346923_zpsxyiloti0.gif
Old Aug 12, 2016 | 01:06 PM
LesMyer's Avatar
Or you could just jumper the motor, run it closed, and forget about it!!
Old Aug 12, 2016 | 01:10 PM
LesMyer's Avatar
Thanks in advance.
See step 5 on post#5 and also any necessary subsequent steps if you just want to run it closed without removing the headliner.
