2000 Blazer misses bad when engine is cold
Old Sep 17, 2012 | 07:13 PM
RobD's Avatar
RobD is on a distinguished road
Default 2000 Blazer misses bad when engine is cold
I have a 2000 blazer,that has a severe miss when warming to operating temp.After reaching operating temp,he runs great.New plugs,plug wires,cap,rotor,EGR valve,TPS,IAC,MAP sensor,fuel filter.Everything installed right.Does not miss on idle,but does when driven,until warm.Any and all suggestions appreciated!!!!! Is it possible,the coil could be causing me problems when the engine is cold? Also,NO CHECK ENGINE LIGHT,OR CODES COMING UP!!!
Old Sep 18, 2012 | 11:14 AM
grizzstang's Avatar
grizzstang is on a distinguished road
What brand of plugs, wires cap and rotor did you use? These motors can be fussy if AC Delco products are not used. Not to say you can't use anything else. I know my cap and rotor are not ACD, neither are my plugs and it runs great.
A miss is almost always electrical in my experience so you on are the right path IMO.
Old Sep 18, 2012 | 12:37 PM
50lb_cat's Avatar
Try unplugging the MAF sensor to see if it helps. If it does then clean it with the correct cleaner. If not, I would start with a fuel pressure and leakdown test.
Old Sep 18, 2012 | 09:53 PM
RobD's Avatar
Ive also heard these Blazers are picky! Not all parts are AC.Something to consider!Im thinking electrical also,and well definatly check out all,suggestions. Appreciate It Guys!!!
Old Dec 25, 2015 | 05:18 PM
TumblingDice's Avatar
TumblingDice is on a distinguished road
I just bought a used 1998 Blazer with 90,000 miles and it has this same problem... i.e.; starts OK and then misses when driving until it warms up and then it runs great. After reading the BlazerForum comments I removed and cleaned my MAF sensor with a MAF cleaner spray. That did not help. Next Step is to replace the MAF sensor with a new one. I'll report the results this weekend.
Old Dec 26, 2015 | 09:27 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
How many miles does she have?Have u ever changed out the coil since you`ve owned the blazer?What about the spider injectors..Are they original?If you would like you can test the coil to see if it`s bad or not.I`ve read where if your spider injectors are bad, you will have a miss with no code at all.
Muddigger86
18
Sep 28, 2015 12:04 PM
toddyboy469
Apr 9, 2015 12:48 PM
claughlin89
28
Feb 23, 2011 07:59 PM
wiblazerman
Mar 21, 2009 06:32 PM
ivannj
Dec 19, 2005 07:54 PM
