2000 Blazer no spark but cranks fine
Old Oct 11, 2018 | 07:59 AM
Mritalian69's Avatar
Mritalian69 is on a distinguished road
Default 2000 Blazer no spark but cranks fine
Ive got a 2000 chevy blazer that just recently stopped starting. It was driven to work, and then after when i went to start it, it clicked like the battery was dead and then when jumped it just cranked. Replaced the fuel filter and the pump primes ao its still good, but its not getting spark at all. Tested at the plugs and it just recently got new plugs and wires.
Old Oct 11, 2018 | 08:42 AM
GeorgeLG's Avatar
Work your way backwards from the plugs to find out where the failure is occurring:
no spark at plugs
is there spark at the coil output?
is there pulse input to the coil
is there pulse input and proper power to the ICM
you can also go the other way and start at the ICM
George
Old Oct 13, 2018 | 12:48 AM
Just to cover your bases: Do you have fuel? You might also check the pressure in the fuel lines.
Old Oct 13, 2018 | 11:17 AM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
Have you checked that the coil wire connection at the distributor is on snugly? Sometimes the boot hides the fact that the connector is not on the fitting.
Old Oct 15, 2018 | 01:48 PM
Mike.308's Avatar
...and what brands of the spares did You use? You haven't mentioned the distributor, but, as, for example, I've ordered a distributor rotor once. Brand new, came with "made in china" sign. By looking the quality I've decided to stay with the old, worn out one. There were already some topic where people posted the photos of the poor quality distributor not matching or falling apart.
Old Oct 19, 2018 | 08:32 PM
I got my Blazer cheap because it would crank, but not start, and the previous owner had already replaced a ton of parts trying to get it to run before he finally gave up.
The problem turned out to be a hole burned in the middle of the cheap replacement rotor. The spark was going to the distributor shaft instead of the spark plugs.
Old Oct 19, 2018 | 09:00 PM
GeorgeLG's Avatar
A guy got rid of an entire Blazer because it needed a new rotor? I won't throw out an old pair of jeans with holes in them. LOL.
George
Old Oct 19, 2018 | 09:01 PM
George
He couldn't figure it out. I did.
Old Oct 19, 2018 | 09:31 PM
GeorgeLG's Avatar
Good for you.
George
1acetour
Aug 7, 2023 10:36 AM
lmkokesch@sasktel.net
Apr 19, 2014 07:41 PM
abe_f
Apr 1, 2013 11:19 PM
LO3671
Apr 4, 2010 01:26 AM
joshua2427
Aug 13, 2008 03:51 PM
