2000 Blazer P0360, P0440, P0155
Just bought 2000 Blazer and took to Autozone and they pulled the above 3 codes. for the P0360 I replaced the Ignition Coil. for P0440 not sure what it means. Something about a vacuum. for the P0155 it says heater condition (heated oxygens sensor Bank on Sensor 1).
Should I replace both oxygen sensors? or both.
Here are the code descriptions & links to the diagnostic procedure (if currently available):
P0155 - Heated Oxygen Sensor Heater Circuit (bank 2, sensor 1)
P0360 - Ignition Coil J Primary/Secondary Circuit
P0440 - Evaporative Emission Control System
You can also search for the codes themselves to see what other members have run into.
I would definitely suggest swapping the O2 sensor to the other side (B1S1 location) to see if the code changes to P0135. If it does, then the sensor is bad. If it doesn't, then I would suspect a problem with the wiring.
Warhead
Oct 24, 2011 03:56 AM
Brandie
Nov 1, 2010 06:34 PM
