2000 Blazer - Speedometer not working??
Old Apr 25, 2010 | 06:26 PM
wolv2401's Avatar
wolv2401 is an unknown quantity at this point
Default 2000 Blazer - Speedometer not working??
I just installed a radio into my 2000 Chevy Blazer and now I noticed that my speedometer isn't working. However, the tach and all other gauges are working. I didn't notice this before the radio but I made sure to use the GM Wiring Harness Adapter when installing the radio. I am MECP certified and have been working on vehicles for quite some time now. But, I have never seen this happen before so I thought I'd post the question on here.
Please let me know if you have any ideas. I checked the fuses but nothing was blown as I expected. Since the other gauges are working fine, I almost think it is coincidence.
Thanks for your time.
Old Apr 25, 2010 | 06:42 PM
Does the vehicle operate (shift, drive, run, etc) properly? If so, the speedometer driver in the cluster is likely at fault.
Do you have access to a scan tool capable of reading the VSS output?
Old Apr 25, 2010 | 09:32 PM
wolv2401's Avatar
yes, it runs, drives and shifts perfectly fine. I can have it scanned. What should I have them specifically look for?
BTW thank you so much for your help!
Last edited by swartlkk; Apr 26, 2010 at 06:23 AM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old Apr 26, 2010 | 06:23 AM
Just look for the vehicle speed and verify that the VSS is working. It sounds like the VSS is working properly and the gauge cluster has somehow failed.
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
86sleeper
Mar 15, 2013 06:09 PM
max1995
Dec 6, 2010 08:24 PM
rob2129us
Mar 19, 2008 02:32 PM
bellert
Aug 31, 2006 03:19 PM
