2000 Blazer starts then dies
Old Nov 27, 2012 | 06:15 PM
Silver00LT's Avatar
Default 2000 Blazer starts then dies
Today was the 2nd day in a row my truck has taken 5-10 mins to start. First time was about two weeks ago...same amount of time.
It'd crank up run for a second then die. Brand new F/PUMP which works. Yesterday, I noticed after it finally cranked up it tried to bog down and die again until I gave it throttle. First time and today the truck sat for 9 hours. Yesterday the truck sat for 10 minutes.
I have noticed that it will only crank after seems like the 15th attempt and has to be two tries back to back. Meaning it cranks up...starts dying I hit the ignition and pedal at same time and it fires up. I am losing my job in 3 weeks so really need to figure this out so I have dependable transportation for the new job.
It sounds fuel related, but a factory "security" system I know it could be bad ignition switch.
Today I took truck from 0 to topped out at WOT. Not a single skip so it had fuel the entire time.
My guesses:
Ignition Switch
Fuel Regulator
Spider Injector(I doubt this)
This is doing a number to my battery, and last thing I need is to be left with a dead battery.
Old Nov 27, 2012 | 06:30 PM
Does the vehicle have a factory security system, (not clear in your post).
First step is check fuel pressure and leakdown. That will test the entire fuel delivery system.
Old Nov 27, 2012 | 08:40 PM
alanmead's Avatar
alanmead is on a distinguished road
When you replaced the pump, did you also change
the fuel filter? Very important to do so.
Old Nov 28, 2012 | 03:54 AM
Silver00LT's Avatar
I have Lock/Unlock and then the Security light that has come on while driving nearly a year ago, but it stopped.
It was replaced not long before the pump went out, but I am going to be replacing it as soon as possible. Today if I can squeeze it in.
Old Nov 28, 2012 | 11:37 AM
50lb_cat's Avatar
Are the lights coming on when you turn the key? If they are start with a fuel pressure and leakdown test like captain said.
Old Nov 29, 2012 | 07:18 AM
Silver00LT's Avatar
Last night after class my SECURITY light stayed on again solid, but truck ran as normal.
Last time SECURITY light came on was about 7 months ago when I was cruising down the highway. It did it for about a week just randomly coming on yet staying off when I for back in truck.
50lb_cat - Lights come on like normal. Battery shows correct voltages.
Old Nov 29, 2012 | 03:12 PM
If the "security" light is on, it sounds like a problem with Passlock. The system will allow the engine to start and run for a few seconds, then shut off the injectors if it detects a "theft" situation. If you have any type of aftermarket security system, keyless entry system, or remote start system, the Passlock system may interpret certain conditions as a "theft" situation. If you have another key for the vehicle, try it and see if it makes any difference. If not, try removing the aftermarket equipment.
50lb_cat's Avatar
Have you done the fuel pressure and leakdown test?
Old Nov 29, 2012 | 03:49 PM
Silver00LT's Avatar
Plan on stopping by tonight after class.
Nothing aftermarket. Everything is stock. One key and one remote.
Old Nov 29, 2012 | 07:15 PM
50lb_cat's Avatar
Depending on the results of the fuel test, I would try a passlock reprogram like captain said. There shouldbe a diy here somewhere, I'm on the mobile so finding links is a pain, but check around.
