2000 blazer still hesitates
Old Jul 10, 2010 | 05:12 PM
robbi_carter's Avatar
robbi_carter is on a distinguished road
Angry 2000 blazer still hesitates
my 2000 blazer still hesitates like its not getting fuel or air. if i put my foot in it. it will bog down then take off. plus it has a little "hicup" at highway speeds. here is a list of things i have changed, plugs, wires, rotor, tps, fuel pump, filter, cleaned maf sensor, it starts and idles fine, any help would be appreciated, as you can see it is getting pretty pricey.
Old Jul 10, 2010 | 05:23 PM
nemesis's Avatar
nemesis is on a distinguished road
any diagnostic trouble codes stored current or in history?
Old Jul 10, 2010 | 07:52 PM
95Jimmy's Avatar
95Jimmy is on a distinguished road
Did you use AC Delco plugs?
Old Jul 10, 2010 | 08:05 PM
Survivor's Avatar
Survivor is on a distinguished road
I had similar problems about a year ago, and pretty much replaced the same stuff you did. I would recommend getting a scan tool or finding a scan tool that shows "live Data". Watch your fuel trims while running and see if you get readings like -33 in my case. If that's the case do an aftermarket MFI injector swap. Also make sure your EGR isn't stuck open. I would also recommend checking your O2 sensors, but those are pretty good about throwing a SES light if they are bad.
Old Jul 10, 2010 | 11:22 PM
lean in bay one and two but no codes now but still isnt fixed
Old Jul 11, 2010 | 10:18 AM
nemesis's Avatar
try spraying some carb cleaner around the intake gaskets, also try removing the oil cap while the engine is running and see if it stalls out. Sometimes if the intake gaskets are leaking really bad it will stall. Or remove the pcv valve and breather tube on the passenger side and induce small amounts of propane while watching fuel trim on the scan tool. Also check for vacuum leaks around vacuum lines especially near the pcv
Old Jul 11, 2010 | 10:19 AM
Survivor's Avatar
so by lean you mean the trims are a positive percentage.
Old Jul 13, 2010 | 05:20 PM
BubbaBrooks's Avatar
BubbaBrooks is on a distinguished road
i also have a 00 blazer and it feels like it hesitates when i take off like when it shifts into second gear at first it sounds bogged down then takes back off
justblazin1
Oct 21, 2013 09:16 PM
davtak
Jun 28, 2011 08:47 PM
DAVEHILLIKER
14
Jun 8, 2011 07:59 AM
robbi_carter
Apr 30, 2010 10:15 AM
O_P_PLaya
Headers, Intake, & Exhaust
Jul 3, 2006 06:14 AM
