2000 blazer whining/droning while turning
Old 07-15-2016, 11:27 AM
Jalmquist125's Avatar
Jalmquist125 is on a distinguished road
Originally Posted by sky_blazer
If the front actuator needs to be replaced there would not be vacuum pulling the cable to engage the front differential. If your problem is the front engagement of the differential then I would suspect the switch before the actuator. Also does your 4x4 work when you turn it on? If so then your actuator should be working and it's the switch. I think you can find them at AutoZone or dealer can't remember part number
As far as I know it works when I turn it on. I'd only had to use it once and it worked then. When I press the button for either 4hi or 4lo the light next to whichever button blinks a couple times then stays on
Old 07-15-2016, 11:52 AM
sky_blazer's Avatar
sky_blazer is on a distinguished road
Try this, turn engine on, engage 4hi, get a jack and jack up passenger side front wheel, try to spin wheel, if it spins a little then locks the 4x4
is working. If it just spins and spins the front actuator did not lock the front differential in
Old 07-15-2016, 11:55 AM
Thanks I'll try this later today when I get some time
Reddlyslug
04-10-2013 04:28 PM
jobiscomplete
12-05-2012 04:48 PM
yukonelmo
05-07-2012 11:25 AM
Green87S10
01-09-2012 06:43 PM
blazeratic
06-13-2010 01:32 PM
Quick Reply: 2000 blazer whining/droning while turning
