2000 blazer wont turn over
Old Jan 27, 2014 | 08:37 PM
gothicsatan187's Avatar
gothicsatan187 is on a distinguished road
Default 2000 blazer wont turn over
Last week, i had an issue with the truck turning over, but not starting, i replaced the fuel pump and it started. a few days went by and everything was good, then it stopped starting, but it still turned over. I decided to replace the ignition switch harness under the steering wheel, turned out that the old one had a few bare wires, and was shorting out. After replacing the switch, it turned over and started, but the dashboard was acting funny, the Odometer didn't stay lit while running, neither did the shifter indicater light, and it seemed that the fuel gauge wasn't working. Thinking i had the ignition switch in the wrong position (cause the accessory setting didn't work either) i continued to try different positions on the switch to get it working, while doing that, the truck stopped turning over, and that's where i sit. The security light doesn't turn on or anything either. Any Ideas on what's going on with this thing? anything will help. Thanks.
tonylee
Nov 20, 2014 01:32 PM
Backdraft
Sep 1, 2014 09:08 AM
93preludeSi
Dec 31, 2010 06:46 AM
leebnc
Oct 16, 2010 02:26 AM
XStrobeLX
May 31, 2010 08:16 PM
