2000 blazer wont't start
Old Feb 20, 2009 | 03:58 PM
stark05's Avatar
stark05 is an unknown quantity at this point
Default 2000 blazer wont't start
I got a 2000 blazer, it won't start, its got plenty of battery. When I turn the key to on and jump the little lead and big lead(leads closet to the right front tire)on the solinoid,the truck starts. Also seems that when the truck sits outside for a while (4-5 hours / temp outside10-25 F) it wont start by simply turning the key over, I have to jump the solinoid. When I have it running for a while the truck will start just fine, no problems. I think it might be a park/neutral switch or the key startposition not making a switch. Any Ideas
Thanks,
stark05
Old Feb 20, 2009 | 04:01 PM
Default RE: 2000 blazer wont't start
So by jumping the terminals on the starter solenoid, you can get the truck to start and run...?
This could be an ignition switch problem or could be some other wiring issue... I assume you have checked all of your fuses...
*moving to 2nd Gen Tech* - Technical questions do not belong in General Chat.
Old Feb 21, 2009 | 09:45 AM
stark05's Avatar
yes, when I jump the solinoid I can get it running. The thing that I'm not clear on is that when the truck is warm it starts every time. When it sits in the cooler weather for 2-4 hours I have to jump the solinoid. If a fuse was bad it would do the same thing all the time wouldn't it?
JimmyBlaze541
May 2, 2013 10:00 AM
PCallen
Apr 27, 2010 10:26 AM
bigbbullies
14
Feb 17, 2010 05:36 PM
Haggus
Jun 25, 2009 03:40 PM
fast400
Aug 31, 2007 05:07 PM
