2000 blazer zr2 clicking under passenger dash??? Please help
Old May 4, 2011 | 08:50 AM
Holtsvillefd69's Avatar
Holtsvillefd69 is on a distinguished road
Post 2000 blazer zr2 clicking under passenger dash??? Please help
I just bought truck saw that there was a recall on the hazard flasher does anybody know if that will stop this annoying clicking noise under the dash
Old May 4, 2011 | 08:58 AM
DySfUnCtIoNaL's Avatar
DySfUnCtIoNaL is on a distinguished road
Nope, thats the flasher relay.
Clicks anytime you use the turn signals.
Old May 4, 2011 | 09:20 AM
Yes but it constantly clicks and when I hit the brake it stops!
Old May 4, 2011 | 09:40 AM
Well, that's wierd.
Try changing the flasher and see if it stops?
Can't be no more than a $10 part.
Old May 4, 2011 | 10:14 AM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
multi function switch.jp
Old May 4, 2011 | 10:22 AM
What is the multifunction swich? And is a cheap fix
Old May 4, 2011 | 11:14 AM
Turn signal lever.
About $75-90. new
You might could get one from the pull-a-part for less than half that, but it might be bad also.
Old May 4, 2011 | 12:07 PM
you can use the search function on this site to reveal alot of useful info. Good luck-Jerry
Old May 4, 2011 | 07:24 PM
Moores12345's Avatar
Moores12345 is on a distinguished road
100% sure it's the multi-function switch.
That's the switch that controls your wipers, turn signals, wiper fluid, etc etc. eBay about 100 bucks new. Pull your glove box down and put insulation in there, that will quiet it right down.
Mine went and would go off randomly. Than I just put bubble wrap and insulation in past the glove box and it quieted down tell I got another one.
Old May 12, 2011 | 07:22 AM
leeroy74's Avatar
leeroy74 is on a distinguished road
I had the exact same problem! Multifunction switch is your answer I swapped it out for a new one and problem solved.
