2000 blazer ZR2 how to you do a learn procedure?
Old Aug 17, 2012 | 01:28 PM
  #21
david068513's Avatar
david068513 is an unknown quantity at this point
Ok I just wanted to make sure the sensor wasn't causing more issues and that it doesn't need a relearn to run. I have a friend coming with a fuel pressure gauge tomorrow if it's not raining again.
Old Aug 17, 2012 | 01:30 PM
  #22
50lb_cat's Avatar
Be sure to post back your numbers. Do the test with the key on, engine off! Your initial should be 60 to 65 and shoudlnt go below 55 for 10 minutes. Post back your inital and 10 minute later numbers.
Old Aug 17, 2012 | 01:35 PM
  #23
So what numbers after 10 min are ok?
Old Aug 17, 2012 | 01:57 PM
  #24
50lb_cat's Avatar
Shouldn't go below 55, if it does then that points to either a leaking fuel pressure regulator or leaking injectors.
Old Aug 17, 2012 | 02:01 PM
  #25
Ok thank you for the info. I'll keep you guys updated with numbers as soon as I can.
So I guess today it doesn't want to start. Here is what happens when it doesn't start. I also turned the key back in forth about 10 times with the pump pumping and still did not start
2012-08-17_16-06-51_807.mp4
http://static.photobucket.com/player...-06-51_807.mp4
Last edited by swartlkk; Aug 21, 2012 at 06:18 PM. Reason: *COMBINING CONSECUTIVE POSTS* Please use the edit function to add additional information to your post if another member has yet to reply. Rules are Rules.
Old Aug 17, 2012 | 03:23 PM
  #26
xgiovannix12's Avatar
Did you do the fuel pressure test ?
Old Aug 17, 2012 | 06:50 PM
  #27
50lb_cat's Avatar
It doesn't have to start to do the fuel pressure test! Its key on, engine off!
Old Aug 17, 2012 | 07:24 PM
  #28
I know that. He is just wasteing his time by trying to start it...
Its not going to fix its self.
Old Aug 17, 2012 | 08:50 PM
  #29
I posted before and said a friend is bring a pressure gauge tomorrow if it's not raining and that the video was to show you what it was doing.
Jeez sorry.
Old Aug 17, 2012 | 11:58 PM
  #30
50lb_cat's Avatar
I wasn't trying to imply that you didn't know that 'gio. Just tryin to make sure the OP knows that the truck doesn't need to start lol
