2000 Chevy blazer 4x4 squeaking
Old Mar 17, 2010 | 07:42 PM
Bradley2424's Avatar
Bradley2424 is on a distinguished road
Smile 2000 Chevy blazer 4x4 squeaking
Hey guys i have a 2000 Chevy Blazer ls 4x4 with just under 85,000 miles. I have a bad squeak when i drive on uneven roads. If i am on the highway witch for the most part is pretty smooth and even i have no squeak. I am not super good at fixing cars but I can do simple stuff. I have looked on here about my problem and got some good answers. But the one question I had I could not find the answer. I am pretty sure I know what my problem is. Worn out control arm bushings. I really don't have the skills to do this repair my self or nor do I want tp pay some one to fix it. Is there any way I can grease up the bushings and get them to stop squeaking. Any one have a good tip on what to do beside replacing them. Any ideas you guys have would be great even if it quites it down a bit. On my scale of 1-10 10 being unbearable sound. My squeak is a 5. If you have a idea to get it down to a 2 that would be great. Thanks guys.
Old Mar 18, 2010 | 10:53 AM
Could be any number of things. You should start by spraying some spray lubricant on the joints in the suspension and greasing those points which can be greased. I would concentrate on the sway bar mounts and the control arm pivots at the frame.
Old Mar 19, 2010 | 08:50 AM
what kind of grease should i use and are there any grease tips that i can plug my grease gun in. I found the one ontop of the control arm.
Old Mar 19, 2010 | 08:54 AM
Nothing special is required. General, off the shelf grease will do.
Inner/outer tie rods, pit man & idler arm joints, top and bottom ball joints. Those are the points were you should find a grease zerk. If you do not find one in these locations, then the parts may have been replaced with non-serviceable parts which sucks.
Old Mar 19, 2010 | 11:38 AM
swartlkk thanks for all the help is there a diagram of where all the grease zerk's are at or do i just have to jack the car up and go look for them
Old Mar 19, 2010 | 11:54 AM
xAnarChisTx's Avatar
xAnarChisTx is on a distinguished road
Here you go:
Old Mar 19, 2010 | 01:20 PM
samuknow's Avatar
samuknow is an unknown quantity at this point
I had a squeak last week. just started out of no where. It ended up being the new ball joints I put on. Apparently the place I had the oil changed was not lubing at all. A couple of shots of grease with the gun and all is well. In fact it drives better as well.
bigeddieoh
Apr 19, 2015 11:35 AM
comandoed
Jan 18, 2014 11:27 AM
duckland23
Aug 12, 2012 07:39 PM
l2e19s
Jan 18, 2011 10:12 AM
tpendergraft85
Feb 17, 2006 07:10 AM
