2000 GMC Jimmy ABS?
Old Jul 19, 2010 | 07:29 AM
mikekolb's Avatar
mikekolb is on a distinguished road
Default 2000 GMC Jimmy ABS?
Just bought a 2000 GMC Jimmy 4x4. The guy I bought it from said it needed a new ABS sensor somewhere, however there are no SES or ABS lights "on". The problem is 99% of the time when applying the brakes (and not hard) once I get to between 10 and 9 mph the ABS kicks in. I'm certainly not locking them up, its usually just a gentle slow stop I make. Could this be an ABS sensor? I do know the front brakes are in definite need of replacement (both pads and rotors). Let me know your thoughts or if there is anything I should try.
Thanks!
Last edited by mikekolb; Jul 19, 2010 at 09:05 AM. Reason: MPH the issue occurs at
Old Jul 19, 2010 | 08:09 AM
Flatearthman's Avatar
Flatearthman is on a distinguished road
If a sensor is bad it should throw a code.
check all your caliper to bracket bolts and make sure they are not loose.
Old Jul 19, 2010 | 08:38 AM
A sensor can read low at lower speeds and cause this issue...
Brakes - Low Speed (below 5 MPH) ABS Activation
Old Jul 19, 2010 | 09:04 AM
mikekolb's Avatar
Yea, I just realized it actually happens between 10 and 9 MPH like clockwork... If I pull the ABS fuse temporarily will this cause any adverse problems aside from no ABS whatsoever? I only ask because it gets interesting when the ABS engages at EVERY stop...
Old Jul 19, 2010 | 09:08 AM
Still run through the diagnosis in the link I provided above. I bet you have either a dirty reluctor ring and/or sensor or possibly an increased air gap on a sensor. It's easy and can be done with only a multimeter and a jack.
Old Jul 19, 2010 | 08:45 PM
mikekolb's Avatar
Awesome, thanks for the info guys! I pulled the fuse for now because it was driving me crazy on my daily commute to and from work. On Wednesday I am going to do the brakes and try your suggestions.
Thanks!
Old Jul 31, 2010 | 02:27 AM
The same thing happened to me about a day before your post and was making me crazy around town.
i pulled the fuse and it brakes normaly
However you will lose your cruise control.
Old Aug 7, 2011 | 08:36 AM
theKiwi's Avatar
theKiwi is on a distinguished road
Thanks for that - I'm hoping it will cure this problem on my 2000 GMC Jimmy.
From the bulletin
Use ONLY Rust Penetrating Lubricant, P/N 89022217
What actually is this - can I use something like WD-40 or Kroil or ? or should I buy a container of this from GM?
Thanks!!
Roger
Old Aug 7, 2011 | 11:41 AM
Any penetrating oil will work at getting in there to help get things loose.
Old Aug 7, 2011 | 12:54 PM
theKiwi's Avatar
Thanks!!
bdude273
Nov 22, 2013 08:30 PM
londonmazda
Oct 19, 2010 02:15 AM
Charleen53
Nov 3, 2009 02:06 PM
manfish
Lifting Tech
Sep 16, 2007 12:06 AM
jfoy1984
May 10, 2007 09:24 PM
