2000 GMC Jimmy A/C Question
Old Aug 19, 2010 | 09:03 PM
  #21
porkfriedrice's Avatar
porkfriedrice is on a distinguished road
Originally Posted by helo
You can swap the condenser, hoses, and orifice yourself to save on labor, but the shop will have to install the accumulator when they do the A/C service (has to be installed immediately before they draw vacuum).
Hmm. Can you elaborate? No one else has mentioned that about the accumulator, Haynes doesn't mention it either. I'd rather not screw anything up if you're right though. It's a learning process here for me. Thanks for the reply.
Since the cost of getting the A/C working is going to be relatively high, I may or may not put this off. There's some other things that need attention besides a luxury item like the A/C. I'd still like to learn though, for when the time comes that I do want to fix it. Thanks guys.
Old Aug 20, 2010 | 03:45 PM
  #22
helo's Avatar
helo is on a distinguished road
Yeah it's kind of late in the year to do A/C depending on where you live. If you do it, make sure you run the compressor for 5-10 minutes every week or two in the winter to keep the new seal lubricated. I'd say it'll cost at least $400-$500 to do it (pressure switches, hoses, condenser, accumulator, orifice tube, compressor, A/C tech labor+freon).
It is really nice having A/C if money isn't too tight =).
accumulator/receiver/drier is the same thing different name depending on the application. It is a moisture absorbing canister. On the blazer it's between the evaporator and compressor next to the battery. The core goes bad eventually and it can't absorb moisture out of the r134a anymore. You definitely need one based on that picture you posted. When the system is open, the accumulator absorbs moisture from the atmosphere and it's most certainly saturated. When you buy a new one it has plastic end caps threaded onto the fittings and it's slightly pressurized with nitrogen gas. As I said, let the tech install that when he does the A/C service.
Haynes isn't exactly an A/C repair guide.. I think there are some decent articles on this site, otherwise google is your best friend for learning about A/C. FYI, you have to add pag100 oil to any new components and lube all the O-rings. I forget where I found the oil quantities. I think the blazer is a GM "HT-6" A/C system.
They only thing you really don't need to worry about is the evaporator. Odds are the condenser has a bunch of debris in it from the blown compressor seal, so I'd recommend spending the $80 or whatever for a new one from rockauto.com. Your original pressure switches might be good, but they also might get stuck after a few days/weeks/months...
Old Sep 3, 2010 | 04:17 AM
  #23
So I plan on orderig the parts that I need for the a/c soon, and I had a question about the compressor options on rockauto.com. What are the differences between the ACDelco compressors, such as #1521729A, #1521729, #1520145, #1522220, #1521586, etc? Some have o-rings included in the description, others just seem to have a difference in price. Not sure which one to order. My inclination is to go with the cheapest one, of course, but I don't want to be missing parts that I need, such as those O-rings. If someone could guide me, I'd appreciate it. Thanks.
Old Sep 23, 2010 | 04:17 AM
  #24
So I'm still looking into replacing the compressor on my Jimmy. Summer's over, but what the hell, might as well have it ready for next year. So my new question is about the PAG oil. Before replacing the various parts, I will have the system evacuated and flushed. Does the flush take out all the PAG in the system? The table that Kyle posted in this thread is helpful:
https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/how-much-pag-oil-where-24039/
I know that I will have to add the oil to the compressor and accumulator, but according to the table, that is only about a total of 4 oz. According to this thread:
https://blazerforum.com/forum/tech-articles-diy-29/flux-air-conditioning-part-3-recharging-46165/
the system takes 8 oz of PAG. How do I add the remaining amount of PAG that is needed to the system? That is, if the flush actually flushes out ALL of the oil. The table from the first thread above says that 1 oz must be added to the hoses, 1 oz to the condenser, and 3 oz to the evaporator. Since I'm not replacing the condensor or evaporator, how do I get the oil in them? I'll appreciate any help. Thank you.
edit: Will the remaining oil be added along with the r134a at the shop when I have them evacuate and recharged?
Old Oct 16, 2010 | 10:21 PM
  #25
C210M's Avatar
C210M is on a distinguished road
Default Evacuate and recharge
What is a fair price to have a shop evacuate and recharge my air conditioning system
bdude273
Nov 22, 2013 08:30 PM
mjsk5blazer
Nov 29, 2010 08:15 PM
londonmazda
Oct 19, 2010 02:15 AM
Charleen53
Nov 3, 2009 02:06 PM
jfoy1984
May 10, 2007 09:24 PM
