2000 Headgasket
2000 Headgasket
I got a 2000 4wd blazer for free that needs a headgasket. I can do the job so i dont need to pay labor but i was wondering how much and how hard before i tear into it. The truck is in really good shape but is it worth doing?
RE: 2000 Headgasket
Before you start tearing into your motor, are you sure that it is definatelty the head gasket that needs replacing? What seems to be the symptoms that lead you to this conclusion?
If you search around the forum you'll find that (while it does happen) it is not very common for the head gasket to go on our motors. Usually it is the intake manifold gasket that more commonly needs replacing.
RE: 2000 Headgasket
It has coolant in the cylinders. It sputters while its running and the radiator is blown.
RE: 2000 Headgasket
It sounds very similar to the symptoms I had when my intake manifold gasket went. When your intake manifold gasket goes, it can also allow coolant to enter the cylinders. It sputters because you're getting moisture in the cylinders. When you say the radiator is blown, you're saying that because the temperature shoots off the roof after a few minutes correct?
Check for signs of coolant dripping by the back of the engine near firewall. If the truck is still running Dexcool sometimes it oxidizes at the part where it is leaking, causing a temporary seal which makes it difficult to locate.
Search around the forum for intake manifold gasket leaks. You'll probably find that the symptoms are very close to what you are seing. It's not that complicated to replace, more tedious and time consuming - still much less of a PITA than the head gasket.
RE: 2000 Headgasket
No the radiator has a big hole in it. When u put coolant in it leaks right out and doesnt hold pressure.
RE: 2000 Headgasket
ORIGINAL: 2000_BlzrLT
cochran07
04-26-2011 05:55 PM
