2000 jimmy boggs past 1/2 throttle
Old Sep 14, 2010 | 05:50 PM
2000jimmbo4x4's Avatar
2000jimmbo4x4 is on a distinguished road
Default 2000 jimmy boggs past 1/2 throttle
sorry to say i am back again, this time my hesitation issue is worse and im fed up with it, almost caused me to get into a serios accident merging with traffic. i drove the jimmy basicaly all day today here there and everywere. i used to have a slight 1500-2200 hesitation. now anytime i try and accelerate hard it feels like the fuel just shuts off. its fine under normal driving, i can hear it gasping under WOT or the similar. it has new plugs, wires, cap and rotor. just cleaned the intake. put a thermostat and new coolant in today. new air filter, fuel filter and i do belive fuel pump. as well as lines. i cleaned my MAF as well. It throws absolutely no codes. Help lol
Old Sep 14, 2010 | 06:30 PM
1998MSO's Avatar
1998MSO is on a distinguished road
Hmmmm, just curious, have you ever checked for a clogged catalytic converter?
Old Sep 14, 2010 | 07:35 PM
no i havent, even when hot though , it runs ok untill that throtle point. it even dose it alittle under no load. the exhaust dosent stink or rattle and it seems to flow ok out the pipe.
Old Sep 14, 2010 | 08:41 PM
AUEngineer's Avatar
AUEngineer is on a distinguished road
I know it's not the same car, but I've seen this exact behaivor in a Toyota Camry and a Mazda Miata--in both cases it was the result of a failing O2 sensor. However, both times, the sensor was not bad enough to throw a code. Perhaps the Blazer experts would disagree with me here... just some information from my past experiences.
RBR
Old Sep 14, 2010 | 08:51 PM
really? ive never heard of an O2s causing that kind of major hesitation / bog out. who knows at this point, i cant find any vacuum leaks, i went around with a can of throttle body cleaner and all seemed ok.
levi1a
Sep 24, 2011 07:27 PM
bdl882
Aug 3, 2010 07:00 AM
Fat_Phil
Feb 20, 2009 10:48 PM
goldie
Aug 25, 2008 11:19 AM
99 Blazer 4x4
Sep 6, 2007 05:06 PM
