2000 Jimmy Got some strange problems
Old Jan 14, 2013 | 06:46 PM
medivh25's Avatar
medivh25 is on a distinguished road
Default 2000 Jimmy Got some strange problems
Hello folks this is my first post So my jimmy " 4x4 4 door auto" has a few problems that are kinda strange, any help would be great. Just bought it
1) temp guage will only move to the first line ( changed sensor ) no help
2) very little heat ( I would assume heater core ) Engine does not seem to get warm though.
3) Ses light will not come on all the time with key on, maby 50% of the time. My understanding it should come on with the key then go off after a few seconds every time. I also noted it would not trip the light if I unplug the maf sensor, scan tool picked up the dtc however. Plugged it back in of course.
All that being said the the truck drives fine.
Old Jan 14, 2013 | 07:11 PM
50lb_cat's Avatar
Sounds like you need to replace your thermostat, not sure about the light probelm though.
Old Jan 14, 2013 | 08:24 PM
The instrument cluster is controlled by the BCM, (Body Control Module). The various onboard computers communicate using class II serial data. Without using a scan tool capable of accessing the network, troubleshooting is next to impossible. Something you can try, is remove the cluster and make sure the pins are secure in the electrical connector, the connector is tight, and the pins are mated to their respective sockets.
Old Jan 14, 2013 | 09:48 PM
medivh25's Avatar
Thank you guys, I'm going to test some more stuff in the next few days. The IPC and heater core is suspect atm. Will keep you posted
Old Jan 14, 2013 | 09:57 PM
I think 50lb_cat is spot on with a bad thermostat, and possibly low coolant level.
Old Jan 14, 2013 | 10:04 PM
medivh25's Avatar
yea gonna change the thermostat tomorrow, coolant is good.
Old Jan 17, 2013 | 09:21 PM
medivh25's Avatar
Bad thermostat was the problem for 1 and 2
Old Jan 17, 2013 | 09:32 PM
gitch93's Avatar
gitch93 is on a distinguished road
i also have a 2000 gmc jimmy with automatic climate control and its been pissing me off. the heat dont seem to be as hot and it fluxuates with cold and warm when its on max setting for hot. it also dosent fluxuate through all the climate modes it usually blows at my face all the time. ive changed the climate control panel 2 times and checked for vacum leaks. ive also replaced the vacum sylanoid panel behind the dash and i still have the same problem. i have green coolant and new thermostat and my heat always sits at 1/4
Alexquade
Jun 16, 2013 07:12 PM
james93726
Jun 5, 2012 08:05 PM
98jimmySLS
Lifting Tech
Mar 9, 2011 05:21 PM
aponeil
Lifting Tech
Mar 13, 2010 11:22 AM
davidluzader
Mar 1, 2010 10:25 AM
