2000 zr2 rear glass hinge help
Old Oct 16, 2012 | 07:34 AM
Asuryan9's Avatar
Asuryan9 is on a distinguished road
Default 2000 zr2 rear glass hinge help
So I just bought a 2000 zr2 Blazer. Owner said someone tried breaking
Into the rear hatch at the top of the glass. So no the top drivers
Corner of the glass is raised up a bit and leaks a little. The
Glass obviously isn't bent lol and the body line where the glass
Sits looks fine so I can only assume the hinge is bent out of shape.
Where can I get new ones?
The pistons are bad for that matter, where can I orders them from?
Thanks
Steve
Old Oct 16, 2012 | 07:59 AM
Justproud2b's Avatar
Justproud2b is on a distinguished road
rockauto.com or 1aauto.com are pretty good places from what I've seen and heard. Just searching in google typically gives you the part you need. If you have the part typing in the MIR number will normally pull up exactly what you need in google.
Old Oct 16, 2012 | 03:58 PM
Asuryan9's Avatar
I can't for the life of me find these things by searching. Maybe there is no where to get them lol. Was hoping it wouldn't come down to me taking them off and mashing the one thats bent to look like the other.
Old Oct 17, 2012 | 11:31 AM
Lift supports for tailgate may not be the right one depending if you have tailgate or liftgate http://www.rockauto.com/m/mobilecata...rtnum=SG430018
Listed under rockauto.com for your vehicle < body exterior < lift support
I wasn't able to find a hinge but I am not sure exactly what the window hinges are called look on the hinge for an Mir number almost everything in your truck has one or call a dealer and ask the part you would need and start your search that way. Typically I find it best to call dealer and just ask pricing on whatever as it seems more rude to me to use them as a search engine =) hope this helps
Old Oct 17, 2012 | 04:21 PM
Asuryan9's Avatar
Thanks I found the pistons locally. Can't find the hinges anywhere tho.
I will try calling a dealer I guess and see what they say. Thanks.
Old Oct 17, 2012 | 04:32 PM
step66's Avatar
Hinges should be available from either a dealer(yikes!) or better yet a salvage yard. My Jimmy isn't here at the moment or I would go check,but aren't they WELDED like the door hinges?
scosentino88
Jun 3, 2012 07:12 PM
Frank from Philly
Dec 27, 2011 06:59 PM
fondo
Jun 26, 2010 09:44 PM
global_dev
Apr 3, 2010 11:07 AM
JediKnight2
Dec 19, 2007 09:04 AM
