2001 4.3L Starting problem
Old Apr 21, 2012 | 05:02 PM
impalla350's Avatar
impalla350 is on a distinguished road
Default 2001 4.3L Starting problem
Hey , I have a 01' s10 Blazer 4.3L Auto 115k - sometimes when i go to start the truck nothing happens when i turn the key, the battery voltage is fine, and i can hear the relay click under the hood when i turn the key, but there is no sound at all coming from the starter... no clicking nothing... if i keep cycling the key enough times eventually it starts, and when it does the starting sounds strong and normal... any idea's??? solenoid?? thanks yall
Old Apr 21, 2012 | 05:16 PM
bryanchevytruck's Avatar
bryanchevytruck is on a distinguished road
Try checking the connections at the battery and starter to make sure there's no corrosion and all of them are tight.
Old Apr 21, 2012 | 05:19 PM
pettyfog's Avatar
If the voltmeter drops the width of the indicator needle, that's a good sign of a bad solenoid. If any lights dim, bad connection as pointed out above.
First thing is to pull the starter relay out and look for burnt /discolored pins. Those would idicate a bad connection with the fuse block connectors
Then swap it with the rear defroster relay. Any relay in the underhood block can be swapped with any other marked with the same numbers.
RUFF1962
Jan 27, 2015 07:25 PM
Stablock
May 16, 2011 12:38 PM
lsmobilerv
Oct 12, 2010 01:06 PM
lukewb
14
Dec 2, 2006 02:23 AM
mickey2001
Mar 13, 2006 11:51 AM
