2001 4-dr LT intermittent starting
Old Sep 10, 2010 | 08:58 AM
abadinalbany's Avatar
abadinalbany is an unknown quantity at this point
Hi all-
Intermittent starts on 2001 4-dr 4WD LT. Once it decides to not start, it won't start for a period of hours/overnight. It seems like when it fails to start, it often begins to engage, but doesn't quite make it, and quits. I believe the engine is turning over; if I step on the gas, it maybe seems to rumble/shake a bit more during effort to start?
Allegedly (shady garage) plugs, wires, distributor, secondary AIR pump all replaced 4-5 months ago, when previous apparently moisture-related starting issues encountered and EVAP and AIR codes were preventing passing NYS inspection.
Dealership said something about the fuel pressure sensor before I took it to the shady garage, who didn't replace fuel pressure sensor.
Only codes are P0440. Not the gas tank cap; haven't had it smoke tested, but need to if I'm going to figure out what's throwing the small EVAP leak.
Anything obvious I should be looking at here? I'm hoping to drive this thing through the winter before I replace it, I can't afford to right now.
Thanks in advance-
--ab
(And yes, allegedly the evap vent solenoid was dealt with 4-5 months ago as well.)
(And, yes, again as far as evap, the hoses and fittings around the canister look fine, mostly new in fact. Purchased as such used, two years ago, throwing code ever since purchase.)
Last edited by swartlkk; Sep 10, 2010 at 09:48 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member has not responded prior to waiting 24 hours.
Old Sep 10, 2010 | 06:27 PM
1998MSO's Avatar
1998MSO is on a distinguished road
Could possibly be a fuel pump issue. Have you read and done the DIY article posted on this forum regarding the 96+ fuel system diagnoses?
Old Sep 10, 2010 | 07:17 PM
Bielat16's Avatar
Bielat16 is on a distinguished road
I own a 93 trans am with the lt1. Question one when is the last time you replaced your fuel filter?
Two. Do you have cats on it?
Bielat16's Avatar
im sorry didnt mean to post here. I was on the wrong forum. My bad.
Old Sep 13, 2010 | 07:44 AM
I think you might be right. It was feeling like some sort of fuel issue, but I didn't bother to listen for the pump. It's only starting up intermittently or not at all with the key turned.
Can I roll-start this thing in order to drive it two miles down the road to a garage, rather than pay $150 for a tow?
Old Sep 13, 2010 | 10:38 AM
1998MSO's Avatar
Don't think you can push start the Automatic transmission version, and if it's your fuel pump push starting probably won't work anyway.
You might try this trick; Turn the key to "on" (not engaging the starter) then to "off" several times. If it's a bad fuel pump 'sometimes' this helps get one last go from the pump. Worth a try huh?
Let us know what you find out.
Old Sep 13, 2010 | 11:02 AM
Tried. I think I hit that limit when I picked it up out of the supermarket lot and drove it the 3-4 miles to my office parking lot. (home is another 10 miles away.)
cas
Mar 22, 2014 11:33 AM
IT Technician
23
Jan 10, 2013 12:31 AM
rdshiver
Dec 13, 2012 02:05 PM
AUEngineer
Sep 13, 2010 01:13 AM
c5ce
Jan 17, 2009 09:30 PM
