2001 Blazer headlights not working
Old Apr 11, 2012 | 12:36 PM
achaps81's Avatar
achaps81 is on a distinguished road
Question 2001 Blazer headlights not working
Ill try and make this as simple as I can. Only my passenger headlights work, low and high, the driver side headlights only come on very very dim, and brights do not work. Ive checked the relay in the fuse relay under the hood, and it clicks when i turn it on, only once. Ive checked the fuses inside the car when you open the drivers door, and those are all good. Unfortunately none of them are bad. Im at a loss, I cant drive it at night time until i get that working again. Ive been trying to find the body relay block for the headlight grounding relay, but to no avail. The pictures Ive seen say that it is on the back side of the interior fuse panel, but i cant turn it around to find out. Any help would be greatly appreciated.
Old Apr 12, 2012 | 01:21 PM
LannyL81's Avatar
Do you have an ohm - volt meter?
If so, check the voltage at the headlight connector terminals and also check the resistance to frame (with the headlights switched off).
Could be a dirty ground connection or dirty terminals at the headlight. Also check that the headlight itself is good.....switch it over to the other side just to see if it works.
Old Apr 15, 2012 | 07:43 PM
mrkevinmjr's Avatar
mrkevinmjr is on a distinguished road
hmmmm speakin of headlights... a friend and i both have blazers and have hids in them... the passenger ones are a different shade.. on both... this is the second set i been dealing with with this situation.. craziness....imma check grounds as well.
Old Apr 15, 2012 | 08:06 PM
bobby099's Avatar
bobby099 is on a distinguished road
i was just about to say check the fuses, but no luck did you check the headlight connections? i had this problem before my fuse kept blowing as soon as i turned the headlights on but the harness isnt that hard to change i changed it all and it was just the drl relay i was pretty upset.
Old Apr 15, 2012 | 08:50 PM
achaps81, Wiring is different with or without the ZR2 option. If you're not sure if you have the ZR2 option, check the RPO codes in the glove box for "ZR2".
Underdog51
Aug 20, 2014 06:31 PM
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
CompTechMike
Feb 17, 2012 09:39 PM
sonic2552
Sep 11, 2010 11:54 PM
