2001 blazer little heat
Old Nov 18, 2012 | 09:47 AM
Joey Hunt's Avatar
Joey Hunt is on a distinguished road
Exclamation 2001 blazer little heat
i have a 2001 blazer with 4.3 vorteck at idle it gives off little heat but when it is running at anything above 50 kph it gives off alot of heat does any one what is wrong
Old Nov 18, 2012 | 10:25 AM
LannyL81's Avatar
What does the coolant temp gauge show at idle and also when driving?
Could be as simple as a stuck open thermostat or a vacuum leak. Check the vacuum lines under the hood for splits, especially at the connectors.
Old Nov 18, 2012 | 10:38 AM
Joey Hunt's Avatar
when it idles and when it is on the highway it is about the same the only different is at idle it is cold but when u rev it up it starts to give off heat the gauge shows about half way
Old Nov 18, 2012 | 07:07 PM
Probably just low on coolant. Remove the radiator cap, operate the engine at 1500 rpm at normal operating temperature, and fill up the radiator with Dexcool coolant only. Then make sure the coolant reservoir is at the full line. FYI: These engines are known for coolant leaks from the lower intake manifold gaskets.
Old Nov 18, 2012 | 09:53 PM
thundergod66's Avatar
thundergod66 is on a distinguished road
thats true about the lower intake gasket,replaced mine 3 weeks ago,,
stark05
Dec 10, 2011 11:26 PM
karlonline
Dec 4, 2011 05:43 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
sedatedbylife
Feb 24, 2010 12:39 PM
gojo83
Jan 19, 2010 01:40 AM
