2001 BLAZER LT
Old Jan 8, 2009 | 06:58 PM
  #21
iamfrugal's Avatar
iamfrugal is an unknown quantity at this point
Default RE: 2001 BLAZER LT
You got something there. That's the sound...it sounds like a door slamming, or at least trying to close when I turn off the heat.
Maybe the door is stuck open and it can't close (or visa versa) and therefore causing the air to not blow through at a high pressure?
Bear with me for a moment....what if it is the blend door actuator?Does this blend door actuator have anything vaguely (yes jumping on a limb) to do with 4x4?
Old Jan 8, 2009 | 07:08 PM
  #22
No, the blend door actuator is electronic.
If you also have a problem with your 4wd, then I would be looking for vacuum leaks.
Old Jan 8, 2009 | 07:24 PM
  #23
iamfrugal's Avatar
Okay. So the heat wouldn't be related to a vaccuum leak (that's where I was going with that thought).
I want to fix the heat once and for all. Then I will try to find a vaccuum leak.
I'll let you know the solution.
Old Jan 8, 2009 | 07:34 PM
  #24
iamfrugal's Avatar
Iheara *creak* *pop* from under the dash - passenger'sside. It happens when I turn on the heat on highand then off. This leaves me to believe the blend door might be the culprit.
Old Jan 11, 2009 | 10:29 AM
  #25
iamfrugal's Avatar
Intake valve to the heater core is registering 158 degrees.
Outtake valve from the heater core is registerin 68 degrees.
Heater Core = $95 part.
Labor = 9 hours!!!!
Having heat = priceless.
What more can I do but fix it and move on???
94BlazerGirl
Aug 28, 2014 06:14 PM
PogiMoto
Jun 2, 2014 11:31 AM
hlaverty06
Mar 23, 2014 09:25 AM
hlaverty06
Mar 5, 2014 07:14 PM
beeneeb
Dec 7, 2004 05:10 AM
