2001 blazer misfire
Old Feb 16, 2009 | 08:56 PM
Kwik17's Avatar
Kwik17 is an unknown quantity at this point
Default 2001 blazer misfire
I have a 2001 blazer.. i have a misfire that i have been dealing with for quite a while. it only happens at 2000 rpm.. have changed plugs and wires, injectors, no vacuum leaks changed all the lines. new fuel filter.
anything else you guys think it might be causing it??
Old Feb 19, 2009 | 07:23 PM
blazin8556's Avatar
blazin8556 is an unknown quantity at this point
Default RE: 2001 blazer misfire
i had a similar problem. mine was my ignition coil. then the problem came back but no where as bad. then it was the distributor cap and rotor button. so now i have a new msd igniion coil and an accel cap, and did have a rotor. but it broke in the middle and caused it to miss all the time. so i put a cheap one on cause the accel gave out so easily.
Old Feb 20, 2009 | 03:41 PM
polecat's Avatar
Member
polecat is an unknown quantity at this point
is the check engine light on?
todd89
May 13, 2013 06:46 PM
rrk03300
Nov 15, 2012 10:29 PM
Darla Smith Garrett
Jul 15, 2012 01:54 PM
bamiejurke
Nov 10, 2011 03:08 PM
jcorbeil
Jul 16, 2011 09:22 AM
