2001 blazer overheating
Old Nov 27, 2010 | 12:05 AM
ded2klf's Avatar
ded2klf is on a distinguished road
Default 2001 blazer overheating
i have a 01 blazer and it is overheating i took a look at it and when i opened the radiator cap n put coolant in it she spits it out it comes out like a waterfall when i turn on the car without the cap so i replaced the water pump and the upper intake manifold gasket and the theromastate and the pvc valve i just bought the truck to and also i have no heat i dont know if its the heater core or blower someone please help
Old Nov 27, 2010 | 12:14 AM
Sturg's Avatar
Sturg is on a distinguished road
I would check to see if the radiator is leaking, even the slightest leak (like I had) can cause problems. After you check the radiator check the hoses. If it was the heater core your passenger side floor would be soaked in coolant.
Old Nov 27, 2010 | 12:19 AM
ded2klf's Avatar
i checked the radiator no leak n have all new hoses could it be my head gasket
Old Nov 27, 2010 | 12:25 AM
Sturg's Avatar
Could be the lower intake manifold gasket... You have to get like a mirror to check though.
Old Nov 27, 2010 | 12:29 AM
ded2klf's Avatar
ok imma change out my lower intake manifold gasket tommarow n ill yall know if it worked or not and a question i have no heat what can it be
Old Nov 27, 2010 | 12:36 AM
Sturg's Avatar
The only thing that I can think of is maybe it's a bad thermostat... I'm not real good at diagnosing things lol. I just know about stuff I've already been through with my truck.
Old Nov 27, 2010 | 11:23 PM
ded2klf's Avatar
ok now i have another problem im not getting any juice at all when i crank the blazer battery is still good but need help to figure it out
Old Nov 28, 2010 | 01:14 AM
Sturg's Avatar
Lol, did you find the leak? And what's it doing when you turn the key?
Old Nov 28, 2010 | 08:43 AM
blazerpower's Avatar
blazerpower is on a distinguished road
put uv dye in the coolant and get a uv light and do a pressure test on the system. when was the last time the cooling system was flushed? when was the last time the cap was replaced? what is going on when you try to start it? is it clicking? is the motor cranking but not actually starting? when was the last time you changed the fuel filter?
Old Nov 29, 2010 | 02:12 PM
ded2klf's Avatar
well got it started but i think my head gasket is blown cuz i just saw dat i have sum milk on the oil cap but not alot at all what do u guys think
if i have to change the head gasket on the blazer should i stay with the blazer or am i goin to have more encounters
if i have a leak on my lower intake gasket can that cause my blazer to overheat??????
Last edited by swartlkk; Nov 29, 2010 at 10:04 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
