2001 Blazer starting issues
Old Jan 24, 2014 | 10:50 AM
Joey1986Z's Avatar
Joey1986Z is on a distinguished road
Originally Posted by Captain Hook
It's due for plugs, plug wires, distributor cap & rotor, and both front oxygen sensors at 100K miles. If it hasn't been done, it needs it.
These engines are very fussy when it comes to tune up parts. Aftermarket stuff doesn't perform well or last nearly as long as AC Delco. The cap, rotor and plugs really need to be AC Delco. The spark plugs are AC Delco #41-993 with a gap of .060" Plug wires need to be a name brand like Autolite, Belden, AC Delco, not a store brand like Duralast etc. As for the oxygen sensors, AC Delco and Denso are both good brands. Denso sensors have a faster reaction time and they're cheaper, but they don't last quite as long as AC Delco.
Should O2 sensors be changed if no DTCs are set indicating an issue? I assumed they are working properly if no codes are present.
Thanks!
Old Jan 24, 2014 | 12:02 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
If they have 100k miles on them it would be a good idea. Mine had about 190K on them when I changed them, picked up a few mpg when I did it too.
Old Jan 24, 2014 | 03:44 PM
If you've got 100K miles or more, they're costing you money in fuel mileage! If you wait for the check engine light to come on, you might have been able to pay for one of them with what was wasted in fuel!
Old Jan 24, 2014 | 04:29 PM
Joey1986Z's Avatar
Blazin and Captain,
Thanks for the information. Both precat ones have been replaced in the last 50,000 miles/two years but both were throwing codes when I changed them. I guess if no codes are thrown ,the old sensor is within range, but further from the target, hence MPG not optimized?
Blazin, I assume you changed yours with no codes present and your mileage increased?
Slightly off topic.. my 95 Corvette OBDI threw H44 (Bank 1 lean) and I searched days trying to find a vacuum or exhaust leak to no avail. This reading made the car run rich. MPG dropped 25%. Black smoke was abundant at WOT. I then swapped the sensors and then got H64 lean bank 2 (the lean followed the sensor) swapped them back and got H44. I then disconnected the sensor and naturally got H13 Bank 1 O2 circuit fault; however, the rich condition stopped and MPG went back up to near normal even with the car running in open loop. I plan to get a replacement sensor for it shortly although the car appears to run fine and MPG is normal with the disconnected sensor. I guess I'll go ahead and replace both sensors as they've never been replaced with 254,000 miles. Hwy MPG is about the same as when new (26-27).
Old Jan 25, 2014 | 01:22 PM
Blazin00LT's Avatar
Yes mine had no codes present, but you could watch then on the torque app and when compared to a new Denso unit the new sensor would sweep 3 times for one that the old stocker did. They were just LAZY.
Stablock
May 16, 2011 12:38 PM
cgrett
Nov 15, 2010 09:08 PM
shamimph
Aug 21, 2010 05:53 AM
Sprocket
Mar 20, 2008 09:39 PM
lukewb
14
Dec 2, 2006 02:23 AM
