2001 Blazer starting issues
Old May 22, 2017 | 02:11 PM
Thisisjustme55's Avatar
Thisisjustme55 is on a distinguished road
Question 2001 Blazer starting issues
So last month my fuel filter went out, I knew this because I watched gas pour out every time I turned the key over. Finally got that fixed and then my battery died while trying to start it back up. It just would not catch at all and run. As if I was out of gas, even though my gas hand is always off a bit, I knew there was gas. So it sat here for a month in my driveway. Bought a new battery and now it doesn't die when I'm having to turn it over and over and over until it finally catches and runs. I don't even hear my fuel pump kicking on whenever I turn my key over anymore. Once I get it running and driving, it is sort of sluggish. What do you all think?? Thanks!
Old May 24, 2017 | 12:23 AM
TheSaint's Avatar
TheSaint will become famous soon enough
Have you checked the fuuel pressure?
If not there is a schraeder valve for testing fuel pressure on the fuel line close to the firewall behind the alternator on your car
There is a black plastic cap on the valve you will have to unscrew
Old May 24, 2017 | 10:24 AM
Kangblazer's Avatar
Kangblazer is on a distinguished road
Sounds like your pump is having issues.
Read This thread It should be helpful.
If you didn't find anything wrong with the fuel pressure it could be a distributor related issue or even something wrong with your fuel injector spider.
Old May 24, 2017 | 09:38 PM
I assume you are talking about where someone came and unscrewed that cap and let the air out of the line?? It ran for a day or so, then back to same issue.
Old May 25, 2017 | 02:13 PM
run_girl's Avatar
run_girl is on a distinguished road
The two things I can think of are the spark plugs and alternator. If you're having problems cranking it over - that sounds like it could be either. I might be off base here, but it's that or no pressure to the fuel line. Good luck!
PhantomBlazer
14
Jan 25, 2014 01:22 PM
cgrett
Nov 15, 2010 09:08 PM
shamimph
Aug 21, 2010 05:53 AM
Sprocket
Mar 20, 2008 09:39 PM
lukewb
14
Dec 2, 2006 02:23 AM
