2001 Blazer ZR2 Poor Mileage.
Water pump
Hello again
Today i replaced the water pump with a brand new. But when i finished the truck throw me a code ..p0300,the autozon guy say thats this is a jet problem, spark plugs,wires and all the electrical stuff. Because a misfire.the check engine light came off when i put in drive but the autozone says the p0300.
Also i notticed that my gas drops too much.im suspecting a leak in the spider .
Tomorrow ill do the pressure test because in sundays nobody works in here.
Te scanner thst i ordred .welll his because i dont want tO go to the autozone every time i feel somethings wrong. So this is a good tool. I hope
Well guys . If you have another guess just write me down
Thanks
Thanks
Guest
Posts: n/a
If when your elm cable comes and you have trouble, it might not come with the disc to load the correct driver. Going to look if I still have the driver link to download. Took me like five hours to find it.
OK I got it. It's the skpang you need to download if yours does not work of the bat. Its the driver for most of the clone elm chips. http://www.skpang.co.uk/elm327_USB.htm then find the download for easyobdII. The shareware is free and can be upgraded on the cheap. Don't do any torrent downloads without some good cloud based antivirus in like hitman pro or panda.
pressure test
because i dont have fuel pressure gauges,, i went to autozone. and there are some mechanics out of the store.. and ask if they can put a gauge in the fuel line to check...
so, the guy put the gauge without bleed the line... and i open the key... and the readings was 60.
then i turn off the key and the pressure drops very very low but drops to 40 or something...
note : this is for the First time Turning The key...
so i turn the key one more time and the readings was the same.. 60psi.
and turn off the key and the pressure drops like 54psi.. then slowly rise a little bit then reach slowly to 59.
we wait like 6 minutes and the readings was 58.
in the minute 8 was 56 or 55
in minute 12 or more the fuel drops 54... then 50..
and this is the final reading.. like 15 minutes of readings...
how is this ? good or bad..??
we didn't have time to check the fuel line in the filter.. because there was too many cars in wait for service...
so the guy ask me for 3 dlls for the readings... cheap...
im out of ideas... what im thinking.. maybe the fuel pump it's not in good shape too?
thank you !!!!!!!!!!
well....
i drove the truck all the day. and it feels pretty good.
today i have replaced the cap and rotor. so there's a little more response.
i still have 3 problems...
1- in the AC controls and ventilation. i hear a "shhhhhhhhhhh" some air. vacum air.. is this affect in some way??
2- i have erratic fuel readings..when it is in Neutral or Parking.. the fuel gauge moves one or two marks maximum.
so this is drivin' me crazy.. some people say that it need to clean all the sending unit and other to replace it.. well, sending unit are just cables and contacts.. so these can be cleaned very well.
3- i haven't buy the O2 sensor that originally has crushed the wires.
well...
im low in money right now.. but i need to think more to get cheap...
thank you guys for all the advices..
well...
The erratic readings makes me think it might be a pump issue. The air sound in your dash is probably a vacuum issue . You can try a double dose of techron fuel system cleaner some people have luck with it cleaning the sending unit. Just be sure to use the concentrate. You can check for vacuum leaks by spraying brake fluid around the throttle body and listen for changes in the idle.
thanks for the tip for the erratic reading.. i have a fuel sensor that i already refurbished myself with another pieces and taking the multimeter and the readings are great and smooth. i'll install it when replace the pump...
the vacuum leak.. its from the AC ****.. i saw that 10 minutes a go..
maybe i have to replace it. tomorrow i'll go to the junk yard and i'll grab some other **** .
what do you think about the Fuel Gauge Readings? it's a reason that i have really bad gas mileage?
one last question... how many sensors we can clean and check to maintain the truck in shape...??
thank you! for all the tips and advices ...
doubled my mileage...
after getting' my truck for several problems at start. then i do a full inspection of all sensors that came in my way...
so i cleaned the IAC (Carburetor spray), EGR (with EGR Spray), MAF (with Circuit cleaner), MAP (with Circuit Cleaner)...
and also.. i cleaned all the connections and pins. (with Contact Cleaner and a sharp tool to clean and bend all the contacts.)..
well.. after all this... i was getting after doing this. like 8mpg.. now im gettin 16mpg !!!!!!!!! average.. Highway and City..
so this is much better...
thanks guys for all the stuff and all the help...
I've learning too much in this time...
BlackMatter
02-16-2012 10:27 PM
jstutzman
11-16-2009 02:31 PM
rooster
15
12-02-2006 02:08 AM
