2001 jimmy diamond edit running boards
Old Mar 10, 2009 | 11:48 AM
deadbuzzard's Avatar
deadbuzzard is an unknown quantity at this point
Default 2001 jimmy diamond edit running boards
so i dont know if this is the right spot.
but im looking into purchasing some diamond edition running boards for my 2001 4dr 4x4 blazer.... but they look like they attach on the side
http://img10.imageshack.us/img10/9091/dscf0095p.jpg
http://img10.imageshack.us/img10/7639/dscf0094aqj.jpg
i dont see those holes on my frame. and i found the running boards on gmpartsdirect but they dont show any brackets. where these drilled into the frame? also the center mount seems longer
i guess will these fit the blazer or pass them up?
Old Mar 10, 2009 | 06:07 PM
They should fit, but may require drilling...
Old Mar 11, 2009 | 09:35 AM
drilling bad?
Old Mar 11, 2009 | 10:59 AM
Not unless you do not check both sides of the frame for clearance first.
Old Mar 11, 2009 | 11:36 AM
dont quite get what your meaning by clearance.
Old Mar 11, 2009 | 11:50 AM
By clearance, I mean that there is nothing on the other side that you really do not want to drill through (brake lines, fuel lines, fuel filter, gas tank, etc). You need to put the running boards up there and mark where you want the holes to be, then check on the other side to make sure you are not going to drill through something that you should not.
Old Mar 11, 2009 | 02:54 PM
ok. I was planning on measuring them up and everything. dont want to screw up anything.
DiamondLion
Lifting Tech
Mar 18, 2025 09:00 PM
85kulan
Aug 11, 2009 09:12 AM
muszyngr
Mar 28, 2008 07:02 PM
94blueknight
Jan 1, 2008 09:08 PM
AutomagicLS1
Jan 30, 2007 04:22 PM
