2001 radiator replacement
I really like this forum and have used much of the info here to diagnose past problems on my Blazer, so Thanks to All.
I have a question: Does a 2001 S10 Blazer, 2 WD, Automatic trans have oil cooler lines and/or transmission cooler lines to the radiator?
I need to replace my OEM because the plastic end is leaking. Any tips on replacing would also be greatly appreciated.
Yes, you have both oil cooler lines and tranny lines going to the coolers in the radiator.
Best tip I can give you is do not cross thread the connections when you are putting the new radiator back in.
I'd recommend getting a new all aluminum one vice rebuilding the stock one or replacing it with stock. I also agree with getting the higher capacity one. Just wish I would have done it when I replaced mine but didn't know any better at the time.
bigdaddykane93
Jan 4, 2010 12:03 PM
scottyk
14
Mar 1, 2007 12:03 AM
