2002 Blazer - Loud bang when disengaging from 4WD Hi to 2WD
Old Feb 4, 2014 | 09:58 AM
Bono4783's Avatar
Bono4783 is on a distinguished road
Default 2002 Blazer - Loud bang when disengaging from 4WD Hi to 2WD
I have a 2002 S10 Blazer (3 Button).It shifts into 4WD Hi fine but when I go to put it back into 2 wheel there is a delay, sometime several miles and the a loud bang like someone hit the bottom of the vehicle with a hammer. I have changed out the vacuum front axle actuator (under the battery) and I am in the process of changing the Front Axle Actuator Solenoid Valve, which I currently can't locate on the vehicle (it's not on the firewall).
Am I replacing the right items and is there anything else that I need to look at?
What about a vacuum switch on the transfer case? (Not sure if thats what it's called)
Old Feb 4, 2014 | 10:16 AM
Twip's Avatar
how many times are you going to ask the same question? find the thread that you started it in and keep it on there.
https://blazerforum.com/forum/2nd-ge...ocation-84200/
Old Feb 4, 2014 | 10:47 AM
RJ2004's Avatar
RJ2004 is on a distinguished road
Originally Posted by Bono4783
<snip>I have a 2002 S10 Blazer (3 Button) and I am in the process of changing the Front Axle Actuator Solenoid Valve, which I currently can't locate on the vehicle (it's not on the firewall).
You can't locate it because you don't have one.
It's the 4 button version that uses the firewall mounted solenoid, not the 3 button ones.
I'm not a mechanic, but it sounds like it's your shift motor acting up.
uhlhazard
Aug 8, 2014 09:00 AM
Bono4783
Feb 4, 2014 02:12 PM
ComputerNerdBD
13
Dec 2, 2011 07:12 PM
spaceapex
Oct 21, 2010 07:48 AM
K5Chief
Apr 12, 2010 10:17 AM
