2002 Blazer oil change help
Old Apr 11, 2009 | 03:07 PM
woodsmoke's Avatar
woodsmoke is on a distinguished road
Default 2002 Blazer oil change help
I feel kind of stupid posting such a basic question on here but this is the fist time I've ever tried working on my own vehicle. I have a 2002 4WD blazer and I just want to make sure I have everything ready before I change the oil. I've located the oil filter behind the panel under the radiator but I'm a bit confused on the oil pan and drain plug location. I took a picutre of what I think it is---is that the oil drain plug? (see attachment) I just want to make sure I'm not going to empty the trans. fluid or something. Click on the thumb for bigger pic. Is there anything else I should know before doing this? thanks for any help!!
Old Apr 11, 2009 | 03:15 PM
rriddle3's Avatar
Just follow the oil lines from the filter back to the adapter on the engine. Straight down from there is the oil pan and the plug is on the driver's side about 3 inches frontward. Mine uses a 15mm wrench, but some use a 12mm.
Old Apr 11, 2009 | 03:39 PM
woodsmoke's Avatar
oh---so that isn't the oil pan I pictured?
Old Apr 11, 2009 | 03:47 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
lol just watch out once you pull that bolt out that oil likes to shoot out pretty far, i would suggest putting the drain pan against the driver wheel until the flow dies down a lil.
Old Apr 11, 2009 | 03:54 PM
rriddle3's Avatar
Well, it doesn't look a thing like mine, but since mine is 2WD, they may be different.
Old Apr 11, 2009 | 04:05 PM
woodsmoke's Avatar
Yeah I tried following the lines and it looks as if the lead there. I checked everywhere and this looks to be the only option...and there is a bit of oil on the outside of the pan so it must be it. First time ever doing anything myself so I won't be surprised if I screw it up!
Old Apr 11, 2009 | 04:26 PM
mikeinwi's Avatar
i think the only problem you might run into is getting the old oil filter off, sometimes its like the hand of god put them on theyre so tight, a nice little upgrade to look into is going with a K&N oil filter they have a 1" nut on the bottom that makes it really simple to remove.
Old Apr 11, 2009 | 06:07 PM
woodsmoke's Avatar
thanks for the info
Old Apr 11, 2009 | 06:17 PM
oisinirish's Avatar
Whatever you do make sure to coat the seal on your new filter with oil. Then the next time it won't be so hard to remove.
Old Apr 11, 2009 | 08:37 PM
02 jimmy's Avatar
02 jimmy is on a distinguished road
That looks like the same style plug thats on mine, mine is at the rear of the pan, also yes when I did the first oil change on mine after buying it the filter was very difficult to get off, even with a filter wrench it wouldn't move, ended up punching threw it with a long bar and that broke it free
