2002 Blazer - Won't start
Old Feb 10, 2015 | 05:12 PM
mk123's Avatar
mk123 is on a distinguished road
Default 2002 Blazer - Won't start
This past week my battery light would come on, car had low power then it would kick in, and drive fine. Today, the car did not start at all. I hooked up my battery charger and fully charged the battery. Lights work fine in the car, radio, etc., when I try to start the car it's clicking but won't start. Any ideas? Thanks
Old Feb 10, 2015 | 07:28 PM
bigzimnh1's Avatar
bigzimnh1 is on a distinguished road
Im having a very similar issue. If i find anything out ill let you know and id appreciate the same. I beieve mine the alternator is the issue with battery light. It did the same thing with the light and voltage going up and down. Now the alternator is completely shot i believe as i lost all voltage today and barely made it home. Putting a new one in tomorrow. I also have a no start issue where mine wont crank or anything at times. We shall see how this all plays out and ill let you know.
Old Feb 14, 2015 | 03:32 PM
mk123's Avatar
Any ideas what to try? I took the battery out of the car today and fully charged it. Put it back inside and it's still not working.
Old Feb 17, 2015 | 11:00 AM
Joey1986Z's Avatar
Joey1986Z is on a distinguished road
Any luck?
How clean are your connections and how tight? Sometimes mine will do that, a little wiggle of a cable and it'll start up fine. Have/can you jump it off?
Clicking can be a starter issue, but probably not in your case as you've seen a battery light.
Old Feb 18, 2015 | 06:21 PM
LannyL81's Avatar
mk123: in addition to checking the battery connections, check the cable ends for corrosion....pull the plastic end caps off and look.
Also check the connections on the backside of the alternator.
mikeg
Jun 10, 2012 04:31 PM
MeanGMAN
Sep 4, 2011 06:50 PM
Maniboss
Dec 3, 2010 01:46 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Jorgen
13
Aug 2, 2007 08:05 PM
