2002 blazer zr2 sucking gas like mad
Old 07-22-2018, 03:31 PM
Wolf Killer's Avatar
Wolf Killer is on a distinguished road
George
This is maddening, there are no codes or pending codes, the rig and engine run great, the tranny shifts at the correct RPM. No smoke, smooth idle at around 625 and great acceleration. there have been no misfires so far. there is no EGR on this motor
The engine was replaced with a crate engine that has 30k on it now. The invoice says it replaced the thermostat, a bunch of seals and a gear? No idea on the O2 sensors
I will pull the MAF tomorrow and hose it down and check the throttle plate for gas smell and see if there is any carbon on the bottom of throttle plate. no reason to suspect compression problems Do you think a replacement ECT sensor would be a wise try?
The only problem I can find is watching my fuel gauge drop steadily with in town driving almost a half a tank to go 80 miles of city driving
Thanks,
DB
  #22
Old 07-22-2018, 04:00 PM
Mike.308's Avatar
Sorry for bothering Your conversation, but did You check the engine oil? Does it stink of an (unburned) fuel? What is Your lubrication pressure? Or what is the pressure difference in between a cold/hot engine?
Recently my engine went bye-bye. At start, it was running rich - now I can compare it to another engine I am using right now. It threw no codes till the very end, but was knocking insane loudly. However I must admit, it had a consumption of 27MPG when it died.
In general, these amounts of fuel can't magically disappear. Question is to find out where. Not into a combustion chambers for sure , as per given fuel trims.
EDIT:
Oh, I have another idea for You. Check the engine load while driving. Maybe it is getting more load than expected. You may lookup that value by a dongle using Torque Lite or Car Gauge.
  #23
Old 07-22-2018, 06:30 PM
GeorgeLG's Avatar
GeorgeLG will become famous soon enough
Getting the precise cause without a scope and an advanced scanner is going to be tough. In light of that a new ECT sensor as a trial is probably worth the $15. I don't normally like to throw parts at s problem but ...
the he post above made me wonder if the new engine is the issue or something that got changed like the ecm. To build on the load idea, we should calculate volumetric efficiency. Google VE calculator
george
  #24
Old 07-22-2018, 06:52 PM
Mike,
Thanks for ringing in.
Using the dashboard oil gauge, at engine start I am reading about 55 PSI at a fully hot motor I am reading a flat 40 PSI. The rig had a recent oil change, so oil is very clean and sticking the dipstick right up to my nose I smell no gas. I know man, this is making me nuts. Just recently I drove around and around a big empty parking lot and walked it to see if I could find fuel drips, nothing. I crawled under the rig while it was running to see if I could fuel dripping into the belly pans, I couldn't see or smell any. I have no drips of any kind on the concrete under the rig, just some water drips that don't smell at start up and idle The only place I get a strong hit of gas is when I remove the gas cap, then I get a strong hit of gas fumes. Screw the cap back on and it's gone.
The only knock I can hear is when the A/C clutch kicks in, and then it is a smooth sounding motor, a little loud, but smooth. The motor isn't shaking or chugging, or lifter sound or a sloshing sound that tells the even the most amateur motor head that there is something not right.
I am going to try a couple of things on Monday, if I can't figure this out I may have to pay a shop to put it on a lift to do a search and a fuel pressure test and run their scanner on it to see if they can find anything.
Thanks,
Donald
  #25
Old 07-22-2018, 07:43 PM
GeorgeLG's Avatar
Without the ability to do more intense measurements, the prime candidates are:
MAF
ECT sensor
O2 sensors
Something got changed with the engine swap
Fuel leak
George
  #26
Old 07-23-2018, 11:04 AM
LesMyer's Avatar
LesMyer will become famous soon enough
Originally Posted by Wolf Killer
Since I got it I was getting 12 MPG in city driving, I put in a new air filter, not an oil bath type, replaced a broken vacuum line that went from intake manifold to a T that goes to the charcoal canister I also put in a new PCV valve, Now I am getting like 8 or 9 MPG! No check engine light, and a hand held scanner says there are no codes present or stored from engine.
Just some other thoughts.
Could there be a problem with the EVAP system causing the poor fuel mileage? It did start after hooking up the broken vacuum line to it.
What about the air filter box snorkel being smashed shut where it goes through the radiator support? I mentioned this earlier. Have you checked it?
But either of these I would expect to affect the fuel trims.
  #27
Old 07-23-2018, 01:45 PM
Mike.308's Avatar
...so did You check the load? You can look up a PCM value. How about the drivetrain significantly loads the engine? I am asking as it seems Your engine is more than perfect.
  #28
Old 07-23-2018, 03:35 PM
Mike, I don't have an Android device, so I can't use those Apps, only anIphone 8 that belongs the the woman.
I am going to clean the MAF, and swap out the ECT and air temp sensor in the air intake hose on Wednesday and see if it makes a difference. If not I guess I will need to take it to a shop. I am lucky that I am retired so I don't do a lot of driving, but still it is a killer to keep filling the tank after grocery shopping.
Plus I am wondering if I am sitting on a time bomb with my engine sucking all this gas and no apparent reason, and then have it up and die with no warning.
Thanks everyone.
Donald Bowman
  #29
Old 07-23-2018, 04:39 PM
GeorgeLG's Avatar
Another thought. What is your MAP readout on a cold engine at KOEO?
George
  #30
Old 07-23-2018, 06:45 PM
George,
The outside temerature is 96 degrees.
The engine has been off for two hours when I took these readings
MAP key on engine off 97
Key on Engine on 33
That doesn't sound right does it?
Donald Bowman
Quick Reply: 2002 blazer zr2 sucking gas like mad
