2002 Headlight dim
Old May 26, 2010 | 01:19 PM
Gkolo's Avatar
Gkolo is on a distinguished road
This may have been covered already but, Just bought a 02 Blazer that has dim left side headlights (low & High beam) so i bought 2 replacement bulbs and installed them and still have 2 dim headlights on the left.......Passenger side works fine and so do the left side marker lights on the same wire harness.
Where do i start looking ?
The conections at the bulbs are secure and i see no damage to the wire loom......help
Just pulled out the airbox and checked the ground and it was good. Would the relay under the hood go bad on 1 side and cause this ?
Last edited by rriddle3; May 26, 2010 at 02:16 PM. Reason: COMBINING CONSECUTIVE THREADS
Old May 26, 2010 | 02:09 PM
84BlazerS10's Avatar
more than likely your relay is bad or there is too much resistance somewhere in your wiring.
Old May 26, 2010 | 02:27 PM
Gkolo's Avatar
Ok cool thanks for the info.
Old May 26, 2010 | 04:41 PM
Looking at the wiring diagram for a 2002 non-zr2:
It doesn't look like there is anything in common between the two left side bulbs that doesn't also get shared with the right side...
Old May 27, 2010 | 06:57 AM
Gkolo's Avatar
Default Dim Headlight
Added a new ground wire from the low beam and it still dont work right, i just shut the hood because the wife said i shouldnt be out there cussing at it....lol
So i'm going to add a ground to the high beam side and see if it fixes it because the relay was good.
Old May 27, 2010 | 11:27 AM
Look at the wiring diagram I posted above. You may cause more problems than you originally had by adding grounds into a system as complex as this...
Old May 28, 2010 | 08:19 AM
Gkolo's Avatar
ITS FIXED !!!!! lol
Turns out there is another 15 amp fuse for the headlights in the relay box under the hood.
Now i can start adding my touches to the inside and out, My 97 Blazer was quick and it was a 4x4, This thing is a 4x2 and its a damn rocket ship.....
Old May 28, 2010 | 12:12 PM
I figured it would be something easy and stupid lol at least it always is with my problems. Glad to hear it's fixed though.
Old May 29, 2010 | 09:04 AM
Gkolo's Avatar
Now to tint the windows and find a cold air intake
Old Aug 11, 2010 | 05:34 PM
ludvigsen08's Avatar
ludvigsen08 is on a distinguished road
where did you find this fuse? close to the master brake cylinder?
Jacob Bo
May 3, 2015 12:41 PM
02 extreme
Jan 12, 2013 07:57 PM
phil01ss
May 29, 2006 09:21 AM
jagblazer01
Mar 9, 2006 09:52 PM
jaleg
Nov 17, 2004 02:53 PM
