2003 Blazer loss of power fuel filter problem
Old Jul 20, 2010 | 09:46 PM
David Hineline's Avatar
David Hineline is an unknown quantity at this point
Default 2003 Blazer loss of power fuel filter problem
2003 Blazer this last weekend made a trip to/through/and back to the KC KS area. Probably got some dirty gas at the station in MO that I got a free opossum with a fill up. Anyway the next couple days were darn hot, the Blazer had no energy, it got around but the shift points were way off. It would down shift two times just to go up a slight grade at highway speeds.
Example if cruise was set at 65mph, and I pushed the accelerate button on the cruise 10 times to kick it up to 75 it would have to shift down two gears to make it.
Another example was if going 75 and enter a construction zone, I would hit the down button 10 times it would slow down to 60 then have to shift down a gear to get it back up to the intended set point of 65.
Wanted to start with a fuel filter, could not break the fittings loose so I took my new bought filter and took and had it changed. Life is back in the Blazer all is good.
Speaking of setting service codes would a scanner have indicated a lean condition without setting a check engine light?
Skyray
Jan 9, 2014 04:57 AM
trk1363
Nov 4, 2011 06:42 AM
bryanmine
May 19, 2011 11:27 AM
doobie98dailydriver
Mar 24, 2010 10:40 AM
ckevroll
Oct 17, 2009 11:04 AM
