2003 Chevy Blazer with flashing "Check Gauges" light
Old Aug 19, 2008 | 07:37 PM
downja's Avatar
downja is an unknown quantity at this point
Default 2003 Chevy Blazer with flashing "Check Gauges" light
On my 2003 Chevy Blazer the "check gauges" light has been flashing, and at the same time, the oil pressure gauge will drop when the light flashes, but comes right back to normal. Any suggestions?
Old Aug 19, 2008 | 07:53 PM
WolfPack's Avatar
Default RE: 2003 Chevy Blazer with flashing "Check Gauges" light
When was your last oil change? You really shouldn't be driving...at all...if you're losing oil pressure for any reason. Thats about the shortest how-to on killing your engine.
Old Aug 19, 2008 | 08:23 PM
Could be a loose connection at the oil pressure sending unit underhood. It is located to the driver side of the distributor near the brake booster.
Old Aug 19, 2008 | 08:25 PM
WolfPack's Avatar
Would the loose connection trigger the check engine light?
Old Aug 19, 2008 | 08:32 PM
It would cause a check gauges light (as the OP stated) as the PCM thinks there is zero oil pressure. But should not cause a check engine light.
bulldogauto
Jun 28, 2021 10:41 AM
Ricschulze
Jun 18, 2013 09:48 PM
JerryB52
Jun 5, 2011 06:30 PM
boscoedoodle
Nov 24, 2009 10:56 PM
Calais225
Jan 24, 2007 09:57 PM
