2004 4.3 Blazer Spider Injector removal
Old Jul 27, 2011 | 12:12 AM
kaynos's Avatar
kaynos is on a distinguished road
Question 2004 4.3 Blazer Spider Injector removal
Purchased a replacement spider assy and plugged it in easy, reassembled engine. Engine had single misfire and it got worse now has severe misfires and barely runs. I think the spider assembly is defective.
Now trying to remove the new injectors from intake, and they are separating at the injector leaving the plastic tube in the lower intake manifold. Anyone have a good way to remove these plastic tubes? Do I need to pull the lower intake again and drive them out?
Thanks for your help..
Old Jul 27, 2011 | 12:53 PM
The updated MFI spider really clips in hard. They aren't impossible to remove without removing the LIM, but it can be quite a task to get them out without breaking or mangling them.
Old Jul 27, 2011 | 08:52 PM
joey's Avatar
joey is an unknown quantity at this point
Hey Kaynos,
By any chance did you purchase a Delphi unit? I just replaced mine and I think I have the same issue. Removed the air intake from the throttle body and could smell raw gas under the butterfly valve.
Thanks,
Joe
98 Blazer LT 4x4
4.3 vortec auto
Old Jul 28, 2011 | 03:16 PM
pheaton's Avatar
pheaton is on a distinguished road
Funny.. Swartlkk, remember I had this same issue with the Delphi unit? I went back to the original one and it worked fine. Wonder if Delphi one is messing up, or if we are all installing it wrong? I'm glad to know that I'm not the only one. I'm curious to see how this one plays out. I suppose I would try to get a Delco one the next time I tried it and see if that helps. To get the plastic caps out I would try to use a probe to try and slide it out.
Old Jul 28, 2011 | 04:48 PM
The AC Delco unit I installed in my old '00 Bravada came with specific instructions pertaining to the routing of the #3 injector. Did the delphi units come with this instruction?
Old Jul 28, 2011 | 06:06 PM
joey's Avatar
It came with instructions on routing the #3 hose behind #1 and plugging the injectors in sequence. Installation went smoothly and nothing seemed to bind. After reading some online reviews, I come to find that others have had similar issues with this unit.
Old Jul 29, 2011 | 09:44 AM
kaynos's Avatar
Mine wasn't a new delphi part that I know of. I purchased a reman unit from injectorwhse.com. It appears near identical except the injector insulator tubes are brown. I thought the price was reasonable but I'm on my second defective one, both leaked gas gas terribly. I verified by connecting fuel lines to it with the upper intake manifold off and performing a pressure test. I can't get the plastic injector insulators out of the intake manifold. Perhaps I am installing wrong. I tried to route each injector with minimal stress to the connections. Bad luck I guess.
It's looking like I'll have to pull the LIM again, new gaskets prob too. This project has become a nightmare.
Does anyone have a source for Delphi part new along with a part number for a 2004 4.3 blazer?
Old Jul 31, 2011 | 07:12 PM
kaynos's Avatar
Can I get some input on new spider injectors for a 2004 Chevy 4.3? Where is a good place to order them and Are the Delphi's the best to order for new replacements?
Old Aug 1, 2011 | 09:58 AM
pheaton's Avatar
It said to route under #1 if that is what you mean. They aren't very easy to move and almost feel like you are forcing them where they don't want to go, gave me a strange uneasy feeling when installing. I never like that feeling. .
Old Aug 1, 2011 | 11:04 AM
Yeah, they can be stubborn. And yes, that is what I was talking about with the #1 & #3 routing. If you don't route it correctly, the hose can rub against the spider bracket and possibly ground out an injector or cut a line if left long enough.
It's lookin' like the Delphi units are somewhat problem prone. I've replaced 3 now and always used the AC Delco unit. No problems with any of them.
