2005 to 2001 Swap
Old Sep 11, 2015 | 08:38 AM
Caddyman's Avatar
Caddyman is on a distinguished road
Default 2005 to 2001 Swap
I have swapped a 2005 4.3 into my 2001. I replaced the transmission and transfer case as well. Upon trying to start, I get a brief start but won't continue to run. I have good fuel pressure. I swapped all of the engine/trans wiring as well as the ECM. Does anyone have any advice as to where to look.
Thanks.
Old Sep 12, 2015 | 09:20 PM
blaz's Avatar
blaz is on a distinguished road
Do a security relearn search. Jamaroon had to do this a couple of times on his Sonoma.
Old Sep 12, 2015 | 11:12 PM
richphotos's Avatar
I moved this so second gen tech since this is not really a build thread.
Old Sep 14, 2015 | 08:27 PM
Caddyman's Avatar
I did the relearn and the security light went out. It still won't run. The fuel gauge only works in the start position, seems to cut out in the run position. I switched the BCM to the one from the 2005 but it didn't make any difference. Any ideas what I should try next?
RickBlazer
Jun 23, 2011 04:59 AM
m00nwater
Feb 17, 2006 01:04 PM
Bgray
Jan 21, 2006 02:30 PM
m00nwater
May 23, 2005 07:57 PM
