2005 4.3l not starting
Old May 20, 2014 | 02:16 AM
Tacticalbum15's Avatar
Tacticalbum15 is on a distinguished road
Default 2005 4.3l not starting
So the engine turns over but it won't start. There's a replaced fuel tank, fuel filter, fuel pump, and relay switch. Maybe the spark plugs? But I can't seem to find them. Any help?
Old May 20, 2014 | 10:00 AM
burned's Avatar
burned is on a distinguished road
Old May 20, 2014 | 10:16 AM
jpimp's Avatar
jpimp is on a distinguished road
any engine codes?
Old May 22, 2014 | 07:49 PM
Default Update
Fixed a ground wire on fuel pump, got it started but didn't last long. Any suggestions?
Old May 22, 2014 | 08:14 PM
vegie_2's Avatar
vegie_2 is on a distinguished road
I had my blazer crank but no start and replaced fuel pump,Spider injector and still had intermittent crank no start everyone said replace cap and rotor with AC Delco.
I did and it starts every time. those cheap cap and rotors fail in a year or two so take my advise and get the cap and rotor from AC Delco
Old May 23, 2014 | 09:20 AM
burned's Avatar
A couple. Start testing.
What is the fuel pressure and does it hold for 10 minutes?
Do you have spark at the plugs and is it a nice pretty blue color?
Old Jun 1, 2014 | 09:11 PM
Okay so I tried everything you guys suggested and still no improvements. So I decided to just take it to a Mechanic and it turns out it was the Fuel Injectors and the Catalytic Converter. Thank you guys so much for your help.
imrangadit
Sep 19, 2010 02:24 AM
Debbie
Jan 27, 2010 07:42 AM
ninepointer
Jun 24, 2008 12:00 PM
Sprocket
Mar 20, 2008 09:39 PM
trailblazer333
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Jun 24, 2007 09:41 AM
