2005 Blazer 4wd
Old Mar 16, 2014 | 07:37 PM
joejiz's Avatar
joejiz is on a distinguished road
Default 2005 Blazer 4wd
Hi
I have a grease gun and wanted to grease the front end, can someone be so kind to tell me how many and where I might expect to find them?
I'm not super familiar with the front end names so if you could use a bit more explanation I'd appreciate it.
My grease gun was filled by a shop specifically for front end's awhile ago.
Old Mar 16, 2014 | 07:56 PM
Jamaroon's Avatar
Upper ball joints, lower ball joints at the ends of the upper and lower control arms.
Inner and outer tie rod ends, outers are attached near the where the wheels mount, then follow that same rod to where the inners are close to the frame.
Idler arm, attached to the passenger side frame rail and steering linkage (same bar the tie rod ends are attached too)
Pitman arm, attached to steering box and steering linkage
Old Mar 16, 2014 | 08:34 PM
LannyL81's Avatar
Good luck getting to the idler arm and pitman arm and even the inner tie rod ends can be a challenge at times.
Hope your grease gun has a flexible hose on it....you will need it.
Wipe off grease fitting before and after.
Again, good luck with this.
Old Mar 17, 2014 | 03:44 PM
joejiz's Avatar
Thanks everyone for the reply and info! I now have the knowledge and will post some pics soon!
joejiz
Jul 31, 2017 05:29 PM
joejiz
29
Jul 29, 2015 09:51 AM
BRoss99
Headers, Intake, & Exhaust
Oct 30, 2014 10:23 AM
joejiz
65
Apr 15, 2014 07:58 PM
jtbwatson
May 26, 2013 02:59 AM
