2005 blazer Purge valve code p0496
Old Jan 21, 2013 | 01:36 AM
joejiz's Avatar
joejiz is on a distinguished road
Default 2005 blazer Purge valve code p0496
Hi
Can anyone help me find out what this means?
I just replaced my selnoid at the very back by tank for another error code I had then a month later this one happened.
Any help would be great in diagnosing it.
For some reason the truck being in -29C for two days in a row then I started it.
The engine light came on and this is what code reader said.
The truck is now back in warmer climate. +10 C.
Old Jan 23, 2013 | 03:20 PM
joejiz's Avatar
No idea anyone? Pretty busy time on forum. I'll see if I can hunt down some more info.
http://www.obd-codes.com/p0496
Old Dec 15, 2013 | 03:15 AM
joejiz's Avatar
Default picture of part in engine bay?
Hi
Does some have a picture of the part?
I found this link that could help me test ..
http://www.justanswer.com/chevy/3x1a...runs-fine.html
Old Dec 15, 2013 | 09:29 PM
joejiz's Avatar
Default picture of part on 05 please?
P0496 Chevrolet Evaporative Emission System Flow During Non-Purge OBDII Engine Light Trouble Code | Engine-Codes.com
also found this link that gives me picture of where the unit is under the hood!
Finally!
https://blazerforum.com/forum/engine...i-think-30022/
Old Dec 24, 2013 | 12:43 AM
joejiz's Avatar
Old Dec 24, 2013 | 10:10 AM
CAB's Avatar
CAB
CAB is on a distinguished road
So did you fix it?
Old Dec 24, 2013 | 07:48 PM
If activated charcoal from the canister breaks up and makes its way to the canister purge solenoid, (right side of intake plenum) the small pieces can hold the solenoid open. This causes vacuum to be applied to the tank when the canister vent valve, (by the fuel tank) is closed. If there is a vacuum when you remove the fuel cap, there's a good chance this is the problem. Remove the purge solenoid and apply vacuum to the nipple that sticks into the plenum, it must hold vacuum. Note: If the solenoid is removed, the silicone seal MUST be replaced.
Old Dec 25, 2013 | 01:32 PM
joejiz's Avatar
Hi Captain hook!
I haven't bought the part on the intake manifold yet.
A: There is no vacuum when I remove gas gap
A: Hard start condition happens after I fill up tank with gas
Other info: It does have a rough idle
To clarify:
Remove to bolts and lift up on solenoid(at intake) (when truck is cold)
Put mighty vac at nipple that pushes down into intake.
Apply vacuum ( but do not disconnect external rubber line that goes to rear of truck)
Correct?
Q: The silicone seal is sold when I buy a new part and is like a gasket?
Old Dec 25, 2013 | 01:38 PM
Totally remove the purge solenoid from the vehicle to do the vacuum test. You can get the seal separately at a GM dealer, or it should come with a new solenoid.
Old Dec 26, 2013 | 09:15 AM
joejiz's Avatar
Thanks for reply!!! To disconnect the hose from the solenoid do I just "pull" it off as hard as I can or do I need to remove the grey c-clip from it?
