2005 Blazer/transfer cases changing?
Hello All.This is my first post.I have 2005 2 door Blazer.It has 30,000KM.In my manual for service,it says to change my transfer case fluids if applicable at 83,000KM.When I go to change my oil (Mr Lube),they say every 24,000KM or two years. My manual does not have a time factor.Who is right?I should add my Blazer is a 4x4.These changes of the transfer cases is costly at around $320.00 .
Caution: You must make sure you can get the FILL plug out before you remove the drain plug.
gordonltaghon
15
05-14-2013 06:25 PM
oldsbravada2000
01-01-2013 05:23 AM
