2005 chev blazer 12v at trailer plug not showing voltage
Old May 13, 2021 | 06:38 PM
joejiz's Avatar
joejiz is on a distinguished road
Default 2005 chev blazer 12v at trailer plug not showing voltage
Hi there,
I have no trailer package from factory. The trailer is not hooked up. I have 4 prong connector
I am showing all the correct voltage for brake and signaling but I get 0V for running lights for trailer (brown wire) at the plug using DVM.
Gnd plug - to blk on voltage meter
Brown plug - to red on voltage meter
Cover up "eye" phizo sensor ON DASH - i think it's called that - thus trigger Daytime running lights. Perhaps not applicable but it's on. Also turned on full lights switch to top direction.
No 12 V found on BROWN wire.
Things I have done:
Turned blinkers on key in on position
Tested the following fuses with probe light!
TRL LTRN - 10AMP - PASS
TRL RTRN - 10 AMP - PASS
TRL B/U - Fuse okay visually but no PROBE LIGHT ON ( trailer backup lights???) which of course i don't use or have anyway. so OK TO IGNORE I ASSUME
TRLPRK - 10 AMP - PASS
Gosh if the green and yellow check out using the GND and they work, that means GND should work.
Thanks guys.
Old May 13, 2021 | 07:24 PM
joejiz's Avatar
Well if all fuses are good and we know ground works since brake lights , I figured why not start undoing all the electrical tape and follow it back, I found a huge "CLUMP" where someone had used butt connectors .. sure enough
YEEE OLD BROWN WIRE WAS corroded off.
Repairing and will re-test.
Walleye Hunter
Jul 30, 2020 08:45 AM
Slugranch
Feb 4, 2018 03:55 PM
Zyan
17
Oct 25, 2012 08:43 AM
thered1
May 25, 2012 07:11 PM
Kellen
Oct 10, 2007 06:48 AM
