2005 ZR2 z Radiator flush help
Old Aug 13, 2021 | 04:31 AM
Sandor's Avatar
Sandor is on a distinguished road
Default 2005 ZR2 z Radiator flush help
Just picked up a 2005 zr2 Blazer and went to do a radiator flush but can't locate a drain plug, what am I missing. I found what looks like it should be the drain but it has no plug. Is this not the drain, any thoughts? Thanks
Old Aug 13, 2021 | 08:02 AM
I want to say someone put a screw in that hole lol(NOT so lol.....)
Old Aug 13, 2021 | 05:53 PM
I took me a moment to get my bearings from your picture. As Don said, it looks like some plugged the drain for the spigot by shoving something into it.
(picture grabbed from RockAuto)
Old Aug 17, 2021 | 08:27 PM
RedValor's Avatar
RedValor is on a distinguished road
How's the quality of the coolant? If it seems really bad, it may be a good idea to just replace the radiator.
When I bought my 4WD 2Door Blazer with 110,000 miles on it at the time, A/C system had no heat. Soon after driving it, the water pump went bad and I replaced it.
After replacing the water pump, I decided to flush the heater core, and that's when I discovered an orange snot that was clogging it up. It still had the factory original DexCool that caused these sorts of problems. That's when I decided to replace everything in the cooling system.
Old Aug 30, 2021 | 10:50 PM
reway's Avatar
reway is on a distinguished road
I have an 05 non zr2 and I’m looking to do a coolant flush soon so I checked out my drain plug and I have the exact same thing. Very strange. I guess I will just pull the lower hose.
Old Aug 31, 2021 | 08:22 AM
LannyL81's Avatar
Must be what people do when the drain plug gets broken.....
Old Aug 31, 2021 | 12:59 PM
Wondering how many more 05s are like this..
Old Aug 31, 2021 | 02:18 PM
reway's Avatar
Yes it’s very weird, I wonder if all 05s could be like this maybe.
Old Sep 1, 2021 | 05:50 AM
puttster's Avatar
My radiator was full of black crap that settled to the bottom and presumable into the lower hose so even if I could open the drain it wouldn't drain much. I couldn't get to the hose. so I took it to a radiator shop and for $400 they drained everything, replaced the rad and now I enjoy opening the cap and seeing a clean light green coolant.
Old Sep 7, 2024 | 02:56 PM
Kurtbes11's Avatar
Kurtbes11 is on a distinguished road
Default My drain plug looks the same.
I have an 05’ ZR2. My drain plug looks just like this one… Anyone find a way around this?
