231 conversion help
Old Feb 7, 2009 | 04:42 PM
cejay825's Avatar
cejay825 is an unknown quantity at this point
Default 231 conversion help
I put a 1996 n231 TC, floor shifter and console in my 1995 blazer,now for my problem.The console has a 4wd indicator display built into it,there are two electrical plugs on the back,one goes to the manual 4wd shifter the other has 5 wires and i'm guessing it tied into the main harness. I'm trying to find out what those 5 wires do so I can hard wire them in.Thanks for any help,as there is not alot of info on this console.
Old Feb 7, 2009 | 09:17 PM
Default RE: 231 conversion help
I would bet that one goes to the front axle switch, probably a ground, and then there would likely be an illumination wire. That is just off the top of my head... Did the console come from an s-series truck?
Old Feb 8, 2009 | 06:38 PM
cejay825's Avatar
Yea, It came off of a 1996 blazer ZM6.I'm having a hell of a time finding info on it.
I'm going to try and post some pix
http://i721.photobucket.com/albums/w...5/IMG_2582.jpg
Old Feb 8, 2009 | 08:55 PM
Here you go:
That should cover the 5 pin plug.
Old Feb 8, 2009 | 09:01 PM
cejay825's Avatar
Man, that is great !!!!!!
Thank you, let the wiring begin!!!
Old Feb 9, 2009 | 06:56 AM
SockJock's Avatar
SockJock is an unknown quantity at this point
Blazer ZM6 ? What option was that? I wish mine was the manually shifted version. I may have to look into this.
Old Feb 9, 2009 | 07:28 AM
cejay825's Avatar
ZM6 is the off-road suspension package,one notch below a ZR2,granted thats a large notch.
I don't thinkZM6 automatically means floor shift 4X4.I'm going to go back to the junk yard friday
and get the glove box door to decode it.
Bobcat13
Nov 10, 2013 06:03 PM
91chevywt
Mar 24, 2010 09:24 PM
Magnum
Sep 4, 2008 01:48 AM
2kSnakeEater
May 30, 2006 08:34 PM
