2nd gen help!
Old Jan 8, 2011 | 07:07 PM
chuck s's Avatar
chuck s is on a distinguished road
Default 2nd gen help!
I have a 99 blazer 4.3 4x4 getting a trouble code for secondary air inj. how do Itrouble shoot it ? please help.
Old Jan 8, 2011 | 09:17 PM
Post the DTC's in the order they were retrieved.
Old Jan 8, 2011 | 11:08 PM
AJBert's Avatar
P0410?
Best to rip the system out and have the code deleted from the PCM.
Oops, I didn't type that out loud, did I?
Old Jan 9, 2011 | 10:08 AM
chuck s's Avatar
AJBert, I like the sound of that . How to do that please? chuck s
someone responded remove codes from vcm . possible?
changed coil,mod, cap/rotor getting power on both pins at coil with key on. is this correct. no flash when cranking . whats next
codes come up p04101/2 -2/2
Old Jan 9, 2011 | 10:21 AM
This thread will walk you right through the diagnosis: https://blazerforum.com/forum/diagnostic-trouble-codes-dtcs-49/p0410-explained-35146/
Old Jan 9, 2011 | 02:51 PM
Please keep things in ONE thread. Do not spread things around.
You need to diagnose, then repair the issue. Clearing the codes will not fix anything.
What you have posted really doesn't correlate to a specific DTC... Is it P0410? Or something else? A DTC starts with a letter followed by four numbers.
Old Mar 19, 2011 | 02:26 PM
fixer34's Avatar
fixer34 is on a distinguished road
Had the same problem-intermittent P0410 codes. Pump works. Finally pulled everything apart and found the solenoid/valve that keeps the exhaust from backing up into the pump had a tear in the rubber diaphram. Anyone know where I can get a replacement? Is this a dealer-only item or do they want to sell you a whole new pump assembly. FLAPS doesn't carry it.
Old Mar 19, 2011 | 02:55 PM
The AIR system check valves are available at a number of different stores. The OE# is 12558992; AC Delco 214638, Airtex 1A3057, Duralast E254, etc.
Sisk
Lifting Tech
Feb 15, 2010 07:11 PM
NC93BLAZERLT
Nov 23, 2009 09:12 AM
old skool luvr
Nov 10, 2009 09:20 PM
94blueknight
Apr 6, 2008 08:34 PM
TripleBlackBlazer
Apr 3, 2008 06:48 PM
